» Insurance
McCoyMotorsportsMotorcycle.comATV.com - Write Your Review and Win!
Old 09-27-2009, 07:46 PM   #1 (permalink)
sitting for a year
I just bought a 92 ZX11 with 16,238 miles on it.
And it has been sitting for a year what should I do first before I try to start it?
wagonmaster69 is offline   Reply With Quote
Old 09-28-2009, 09:45 AM   #2 (permalink)
BlackFrost's Avatar
I Ride: Suzuki TL1000R
i'm not a mechanic yet..but i'd start with some basic things..drain the old gas from the tank..change oil coolant plugs filters..clean carbs and charge battery before you start it..and before you ride replace brakes and fluid on front and back..replace tires and inspect/service your chain...
atleast thats what i would do..
...its not how much horsepower you have but how much are you willing to use?...
BlackFrost is offline   Reply With Quote
Old 09-28-2009, 08:29 PM   #3 (permalink)
I'm going to do that but what about when you pull the plugs and put something in the cylinder so the rings dont bind?
Old 09-29-2009, 08:59 AM   #4 (permalink)
BlackFrost's Avatar
why do you need to put something in the cylinders?...
Old 09-29-2009, 11:20 AM   #5 (permalink)
I just dont want to take a chance of the rings gouging the cylinder walls from sitting for so long.
Old 09-29-2009, 11:23 AM   #6 (permalink)
Jet
I Ride: ZX-11, Ducati 1098, numerous BSAs and Triumphs
I'll be perfectly honest and say I would probably be too lazy to do all that just to get it running unless I KNEW it needed it. You said before you "start it" so for me, I would drain the gas and replace that with fresh and put a new battery in it and that is it. If it will start after that, then I would start looking at the other things. Now I'm not saying you don't need to do those, just that I don't think it is necessary to go to all that trouble before you even know if the thing will turn over and idle. If you get it running, then I would perform many of the other maintenance items but even those would depend on their condition. I've seen sparkplugs go 100,000 miles before they needed replacing. If you have any maintenance information from the previous owner, that might give you a better idea how much of the rest of the work needs to be done. I'm putting my ZX-11 back on the road after sitting for a long time and really all it seems to need is a thorough carb cleaning.
Respectfully,
Jet
1969 Triumph Trident
1970 Triumph Bonneville
1970 Triumph in Trackmaster Frame
1969 BSA Lightning
1970 BSA Rocket 3
1973 Honda TL 125
1974 Yamaha 250 in Champion Frame
1984 Honda XR 100
1991 Kawasaki ZX-11
2007 Ducati 1098
Remington 700 .308 in Accuracy International Chassis
w/Leupold 4.5-14x50 Gen2 FFP mil dot scope
..don't run, you'll only die tired..
..a sucking chestwound is nature's way of telling you your cam and concealment isn't up to scratch..
Jet is offline   Reply With Quote
Old 09-30-2009, 08:43 PM   #7 (permalink)
I Ride: 1994 ZX11D
I just started my bike after being deployed for a year. First I changed the oil (too bad I didnt read about the 2 oil plugs an hour ago) I replaced the fuel filter, drained/replaced the gas, changed the spark plugs and charged the battery. I had to also change some other things, but that is not really related to sitting around for a year. It took a minute for the bike to fire up, but on about the 3rd or 4th try, it came to life. By the way, while the plugs were out, I spun the engine over for a few seconds (the fuel tank was off also) in order to get the oil moving around. I dont know if that was necessary, but I did it anyways.
RTJ1S is offline   Reply With Quote
Old 09-30-2009, 08:48 PM   #8 (permalink)
I Ride: 1994 ZX11D
By the way, unrelated to starting the bike, I also gave it a full inspection, ensured the brakes were working, replaced the brake fluid and bled the brakes on the front and rear, bled the slave cylinder, checked the air pressure in the tires (mine had newer tires and was stored on a centerstand in a garage) lights, blinkers, etc...
If you are draining the tank and see that there is a fair amount of sludge built up, try using some large flat washers, drop them in the tank, put in a little gas and slosh it around to break up the garbage, drain and do it again until most of the stuff is gone, replace the fuel filters and hope for the best. This is what worked for me.
