Glad to know you solved everything!
I also have an intermittent problem that I first thought the sidestand switch was the culprit. So, I bypassed it and the problem is still present so I deleted the switch from my list. However, reading your post make me believe I could have the same problem you had.
If you have a camera, could you please show me exactly where you by passed the wires? I could probably find it by myself but it would be faster with such a picture. Thanks!
Oh and do you know where the wires were bad? Maybe they were rubbing at a place that could be the same on my bike.
I have a camera, but haven't figured out how to post pictures to the forum yet. I am a little slow out of the gate, so I wil try a detailed description to get you on the right track and maybe I will figure out how to post the pictures soon.
First off, I believe that my probem was the result of a fuel pump fire that occured before I bought the bike. several of the wires inder the seat area are a little crispy.
If you think these wires might be your problem, start the bike, pull the clutch in, put it in first gear, press the plunger switch on the underside of the left handlebar with your finger (do not release the clutch). If this kils the engine, there is some reason that the bike does not want you to ride- it may be the side stand switch.
The wires in question run from the side stand switch, behind the engine and into the main harness just in front of the battery. The easiest way to find them is to start at the switch and follow them up. On my bike when they leave the switch there is one green and one black wire. After about 8 inches there is a connectore plug where they become green/white and back/yellow. Shortly after the connector plug they are joined by a light green wire (neutral indicator light) that originates just in front of the oil sight glass. The three wires are taped together and snake behind the engine up to the main harness in front of the battery. Pull on one end and see what moves at the other. Obviously you will need to remove your seat. You will have much better access if you also remove your tank. I already had my entire fairing off so it was no big deal. If this is all you are doing you MAY be better off to just work around the tank.
On my bike, they used a fire extinguisher for the fire and then never cleaned off the powder. The powder is corrosive, so after sitting for a couple years some things don't want to come apart. I was afraid to pull too hard on the neutral indicator and I couldn't pull the side stand switch wires out without disconnecting the neutral light wire. It was faster and easier for me to just cut them close to the main harness and splice them together. I never did identify where the damage was.
I hope this helps. I am happy to answer any more quesions if I can. I will work on the picures.
