Stupid ? about sprocket removal
I'm replacing chain and sprockets on a '91 11 and can't get the countershaft sprocket nut to break loose. Before I end up really breaking something I want to verify it has normal, right-hand threads, correct?
Been too many years since I've had to remove one. I looked in a service manual I downloaded (for the D models) and it just shows to use the rod in the hole, torque is a hefty 94lbs. My air impact won't budge it, nor can I with a 24" breaker bar; in 1st gear, rear brake fully applied. Lock washer is mangled, but doesn't appear to be hanging it up.
Thanks in advance!!
Jeff
