5150 ConceptsATV.comMotorcycle.comSportbikeTrackGearCheapCycleParts.comRacer Parts WholesaleAdvanstarMotorcycleShowsSuperbikeToyStore.com
Springfield Armory
Old 06-29-2008, 10:22 PM   #1 (permalink)
'94 ZX11 stalls when hot
I have a '94 ZX11, I just changed the plugs, the bike starts great idles well in my driveway, but when I get out on the road, it stalls and loses power when I throttle over 3200 RPM. The only way I can get home is to keep the choke on full and limp my way back. Does anyone have an idea as to what is the matter or how to fix this? I should point out that it was doing this before I changed tha plugs... that's why I changed them. Three out of the four plugs were sopping in oil and the fourth was loaded in black soot!
Cheers,
Greg
gregger is offline   Reply With Quote
Old 06-30-2008, 11:57 AM   #2 (permalink)
Kawi_T's Avatar
I Ride: 2001 ZX12R
check for vacuum leaks
Quote from a Kaw mechanic (my dad)
"Great idea, buy your kid a ninja for his last birthday."
Kawi_T is offline   Reply With Quote
Old 06-30-2008, 04:38 PM   #3 (permalink)
is the air box installed? all ram air hoses and vac lines must be installed.
ninja11zx is offline   Reply With Quote
Old 07-01-2008, 01:40 PM   #4 (permalink)
KawieKrazy's Avatar
I Ride: 07 ZX10R
buy a bike thats not 15 years old, seriously, you have timing, vacuum or fuel problems there, or maybe worse, how many miles are on that old thing?
KawieKrazy is offline   Reply With Quote
Old 07-01-2008, 03:16 PM   #5 (permalink)
Thanks for the smart ass comment! I'm looking for help not bull-shit!
Old 07-11-2008, 03:12 PM   #6 (permalink)
cwill's Avatar
I would chk the fuel pump that is what mine did right before it went out all toghter
cwill is offline   Reply With Quote
Old 07-18-2008, 07:27 PM   #7 (permalink)
I Ride: 1990 ZX-11C
Sounds like carbs to me. Probably need a good cleaning. Might have a look at the fuel filter too. Good luck!
Richter is offline   Reply With Quote
Old 07-19-2008, 12:20 AM   #8 (permalink)
I Ride: ZX11C 1993 , K1200LT 2004
I have a ZX11C 93 and love the old bike . Over hauling the engine now , dont like the looks of newer bikes . Make the old girl run again . Dan
LIDMAN ZX11C
danielfjones is offline   Reply With Quote
Old 08-04-2008, 07:29 AM   #9 (permalink)
ESCLASS's Avatar
I Ride: 1998 ZX-11
Most definitely a fuel starvation issue. No carb trouble there. Start with the fuel pump relay...very quick and easy fix. if its not that then its ur fuel pump. Change ur fuel filter also and check for clogs...its right in line just b4 the pump which is all under the tank. Got nice ones at r&s strauss or whatever chain is in ur area for a few bucks..under$10. Do not! I reapeat..DO NOT! Use the newer little cone filters that they will sell u at the bike shop bcuz they r too small and u will put too much stress on ur pump and blow that or another relay. The relay is clipped on the battery. 20 bucks brand new..free or 10 bucks at a local repair shop.
ES-CLASS
ESCLASS is offline   Reply With Quote
Old 08-04-2008, 07:53 AM   #10 (permalink)
ESCLASS's Avatar
I Ride: 1998 ZX-11
The best/easy part about these parts is that they r not bolted on. They slip on via rubber belt to metal clips. Slip of replace and slip back on..no tools needed except to remove the tank which is 4 bolts. Need any help..provided its not too late..and u have fixed already.. Lemme know.
ES-CLASS
