I'm a tuner for a performance shop here in houston, we build just about anything you can think of car wise. So I decided to build a turbo kit for my 2008 10R.. I was kinda curious as to if there would be an interest in a production bolt on kit for the 08-09. Right now I'm at the stage where I could build this with the intentions of making a bolt on kit. If theres not much interest then theres a bunch of stuff I can skip ahead of and do differently since it won't need to be a plug and play deal.
Basically the kit so far would consist of:
CompTurbo 30R with .47 A/R T3 backhousing w/3in outlet, with their Triple Ball Bearing center section.
Tial Wastegate and BlowOff Valve
Air to Water intercooler core integrated into the intake plenum.
All stainless 321 manifold with double slip fit tubing. ( We may end up using schedule 40 instead if this doesn't prove reliable. But we wanted to try it with the lighter material first. )
It'll come with an inline fuel pump and all the fittings to upgrade the fuel system.
Modified stock secondary (upper) injectors (The stock Keihn injectors flowed about 215CC, our injector guy was able to get 810CC reliably out of them)
An Aeromotive Fuel Pressure Regulator.
If theres an interest in a production kit, I will use the AEM F/IC 8 for tuning. If not I'll use a haltech platnium 1000 or AEM EMS instead.
We only use the best stuff and do things the RIGHT way at our shop and because of that somtimes were a bit more expensive but you get what you pay for.
The AEM F/IC is a WAY better system for tuning a boosted bike then a power commander.. I know tons of people use power commanders and FMUs for boosted bikes but, thats not the right way to do it. If your gonna use a piggy back to tune your boosted bike, the F/IC is a better option since is can both remap your TPS stuff just like a power commander for off boost areas, but then it has an onboard map sensor you can use as a load reference when in boost. So you will have MUCH better control over the tune. On top of that it has ignition control built in as well. All for about the same price as just the basic power commander. The F/IC 8 has 8 injector channels so it can handle the staged injection setup that the 08-09 bikes run with no problems.
I'm shooting for 250HP on stock motor on pump gas, since the compression is a little on the high side on these bikes its kinda up in the air how much power I'll be able to make before running into the limitations of 93 octane. Also were not to sure how strong the stock rods are, but we will definatly put the motor under serious stresses at whatever our final power level is to make sure its gonna hold up. The bike made 159HP with everything stock as it came from the dealer on our mustang dyno ( we have the bike attachment ;) ) SOOO I think 8-10 PSI should get us to the 250HP range keeping the tune pretty conservative. I've got a pretty good track record of breaking power records on stock motors and having them last, so we'll see how it goes.
Then once I get my spare motor built up, we'll put some race gas in the stocker and see how much it'll take before it breaks ;) .. Then we'll know where the absoulte limit is on the stock bottom end.
Heres some pics of some of our work to see what kind of quality and experience we have with boosted stuff.
http://www.houston-imports.com/forum...=503896&page=2
http://www.8thcivic.com/forums/force...ad-07-fa5.html
http://www.youtube.com/user/Bugermass
http://www.youtube.com/watch?v=pWsXy6qYmQA
The work looks better as we got better at takin pics lol..
Well lemme know if theres any questions. If theres an interest and we do make a production kit we'll apply to become sposors on here..
