CheapCycleParts.comAdvanstarMotorcycleShowsSpringfield ArmoryBikeBanditJazzMotorsports.comSuperbikeToyStore.comATV.comSportbikeTrackGearMotorcycle.com Classifieds!
Old 08-04-2008, 10:09 AM   #1 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
inexpensive do it yourself mods
So following the success of kdankenb's do it yourself smog block off, i'm hooked. Are there any other mods that can be done to save weight, increase performance, or otherwise tweak the bike that cost less then 20 bucks, that you can do yourself? throw anything at me.
Vertigo117 is offline   Reply With Quote
Old 08-04-2008, 10:15 AM   #2 (permalink)
kc10maineiac's Avatar
I Ride: 2005 ZX10R
1/5th throttle conversion- 25$, remove secondaries-free, -1+2 $40... if you already have a 520 chain. Remove exhaust butterfly valve--free, remove butterfly valve cable and housing---free
kc10maineiac is offline   Reply With Quote
Old 08-04-2008, 10:45 AM   #3 (permalink)
kdankenb's Avatar
hmm, Shorten exhaust cans ( to SBK length ) or shorter.. cost about $3 in rivets...
Proudly Sponsored by: Evergreen Hardware Stores of Phoenix, www.reesesrocks.com, Dunlop - www.jimcoxracing.com , LP, Amsoil
kdankenb is offline   Reply With Quote
Old 08-04-2008, 11:55 PM   #4 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
whats a secondary? how is it removed? the exhaust butterfly is gone, but how do i remove the valve cable and housing without getting an FI light?
Old 08-05-2008, 03:40 AM   #5 (permalink)
How do you do the 1/5 throttle conversion for 25$ ?
old son is offline   Reply With Quote
Old 08-05-2008, 08:33 AM   #6 (permalink)
I Ride: 2005 ZX10R
ooops, sorry when I say secondary I mean the secondary butterflies located on the throttle bodies. Very easy to do... heres a link on how to remove... http://zx-10r.net/forum/showthread.php?t=51847
Good luck
Old 08-05-2008, 08:37 AM   #7 (permalink)
I Ride: 2005 ZX10R
Check this out....
http://zx-10r.net/forum/showthread.php?t=12698
Old 08-05-2008, 08:48 AM   #8 (permalink)
I Ride: 2005 ZX10R
Cable removal won't trigger FI light, however The housing just will trigger the light. There is a "plug" that can be plugged in place of the housing to trick the ECU that the that its still plugged in.
Old 08-05-2008, 08:54 AM   #9 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
Where can you find said plug?
Old 08-05-2008, 09:02 AM   #10 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
Ok im REALLY interested in the secondaries removal. I was wondering about those... i remember having my old 6RR apart, twisting the throttle with the airbox off, and watching the throttle bodies move... i was wondering why i couldnt do that with my zx10... however, the disclaimer is really turning me off to it... i have a BMC standard filter, a muffler that bolts directly to the headers, and a very rich PC3 map to make it all run smoothly. Do you think this mod would really mess all that up?
Old 08-05-2008, 09:16 AM   #11 (permalink)
I Ride: 2005 ZX10R
Not at all, the only thing you may notice is a slight engine lag upon sharp twist of the throttle.... that lag is very short but engine picks up real quick. Keep reading through that section and you will find many many happy riders.
Old 08-05-2008, 11:16 AM   #12 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
the lag will be due to the lower air preasure, but it'll gain top end through the higher air flow, right?
Old 08-05-2008, 11:32 AM   #13 (permalink)
I Ride: 2005 ZX10R
The only lag you should come upon is an initial throttle turn while in neutral, thats the only time I have had the lag. While on he road I have not heard the lag at all. Secondaries out is more for the low end, it allows more air to get into the engine at lower RPMs. You won't see any difference at top end because when your at the top the valves are completely open anyway.
Old 08-05-2008, 11:39 AM   #14 (permalink)
kdankenb's Avatar
this sounds easy enough... its kinda like having mechanical venturies, like a keihin flat slide... you'll need more throttle control to be smooth, shouldn't really harm anything
Old 08-05-2008, 02:18 PM   #15 (permalink)
Thanks for the advice on the 1/5th throttle. Have emailed and will order.
Old 08-05-2008, 09:30 PM   #16 (permalink)
Vertigo117's Avatar
I Ride: 2006 ZX-10R
next time my gas tank is empty or near it, im doin the secondaries removal.
Old 08-05-2008, 09:58 PM   #17 (permalink)
I Ride: 2005 ZX10R
Why wait, tank has a vacuum seal, even if the tank is completely full it wont leak, however its not the tank you got to worry about its the hose. Hope you like the mod, please let me know what you think. Also if you could put what you think about it in the thread I sent you that has the directions.
Old 08-05-2008, 10:05 PM   #18 (permalink)
I Ride: 2005 ZX10R
Another cheap mod, chop your stock cans.... or aftermarket cans for that matter. I have an 05 and chopped about 8.5 inches off stock can. I know of a few that have taken a few off the 06-07 model as well.
Old 08-05-2008, 11:57 PM   #19 (permalink)
kdankenb's Avatar
don't worry bout the tank. its got a dry break connector, no leaky leaky
somewhere I have the measurements too for the SBK length Akro's if anyone needs them...
Old 08-06-2008, 08:36 AM   #20 (permalink)
nonelower2001's Avatar
I Ride: Blue 08 ZX6R
Good luck
can you do this on the 08 ZX6R also??
AIRFORCE OIF
Blue Halo lights
Extra bright head lights
PCIIIUSB
removed secondary butterflys
Jumper Mod
T-Rex frame sliders
DIY finder eliminator
Gutted Cat
CF Scorpion Slip-on
pro-grip Gel grips
kleen Air mod
Ram Air Mod
Blue ZX6R
Check out my 25 dollar halo lights!!!
http://i46.photobucket.com/albums/f1...6/CIMG1147.jpg
nonelower2001 is offline   Reply With Quote
