» Insurance
Bike Bandit
Old 10-04-2009, 10:24 AM   #1 (permalink)
I Ride: 2001 Kawasaki ZRX 1200R
new member zx11 question
I am rebuilding the forks of a '91 Zx 11C, but have no current access to a service manual. I need capacity and weight recommendations, please.
Thanks
Dick Eastman is offline   Reply With Quote
Old 10-05-2009, 05:56 PM   #2 (permalink)
rnoliver's Avatar
I Ride: ZX-11 D1 Turbo
O crap, this is all D info, sorry. I don't have C info on me.
From the service manual-
Fork Oil Viscosity - SAE 10W-20
Amount per unit- 465 +/- 4ml D3 model- 467 +/- 4ml
when changing- 410ml
Level- 133+/-2mm from top fully compressed w/o spring
131=/-2mm from top for D3
Spring free length 295mm, D3 296mm
Last edited by rnoliver : 10-05-2009 at 05:58 PM. Reason: Read the OP more carefully.
rnoliver is offline   Reply With Quote
Old 10-05-2009, 08:17 PM   #3 (permalink)
Thanks for the effort! Not sure whether the D is the same as C - hopefully some one here has C specs; they could be the same, but I want to be sure. Got the sliders out for P/C, and will have them back at the end of the week, and ready to assemble then. Dick
Old 10-06-2009, 07:07 AM   #4 (permalink)
Hammerhead's Avatar
I Ride: '04 ZZR 1200
PM Claude. He's very knowledgable about ZX-11s.
Old 10-06-2009, 03:48 PM   #5 (permalink)
Thanks.... I'll do that.
Old 10-06-2009, 04:06 PM   #6 (permalink)
rnoliver's Avatar
C is definitely different. Claude should be able to help.
Old 10-07-2009, 01:39 PM   #7 (permalink)
zaneyzrex's Avatar
I Ride: 2000 zrx1100
from what i just seen on www.mrcycles.com theres very little difference in the forks between the C & D... from what i could see the bottom fork tubes looked a little different but other than that they use the same fork tubes etc...
zaneyzrex is online now   Reply With Quote
Old 10-07-2009, 02:57 PM   #8 (permalink)
Jet
I Ride: ZX-11, Ducati 1098, numerous BSAs and Triumphs
Here you go:
Damper adjuster: 2nd click clockwise
Spring preload adjuster position: 6th mark from the top
Oil: SAE 10W-20
Amount per unit: 458 +/- 4 mL
390 mL when changing oil
Fork Oil Level: 149 +/- 2mm (fully compressed without spring)
Fork spring free length: 438 mm
That comes from the factory service manual supplement. Never rebuilt mine so this is where I would start.
Jet
1969 Triumph Trident
1970 Triumph Bonneville
1970 Triumph in Trackmaster Frame
1969 BSA Lightning
1970 BSA Rocket 3
1973 Honda TL 125
1974 Yamaha 250 in Champion Frame
1984 Honda XR 100
1991 Kawasaki ZX-11
2007 Ducati 1098
Remington 700 .308 in Accuracy International Chassis
w/Leupold 4.5-14x50 Gen2 FFP mil dot scope
..don't run, you'll only die tired..
..a sucking chestwound is nature's way of telling you your cam and concealment isn't up to scratch..
Jet is offline   Reply With Quote
Old 10-08-2009, 05:19 AM   #9 (permalink)
Thanks, fellas
Just checked my spring free length from the above info, and found ok.
Turns out there is substantial difference between C and D models.
Appreciate the help!
Dick
