» Insurance
SportbikeTrackGearMcCoyMotorsports Motorcycle.com
Motorcycle.com Classifieds!
Old 06-17-2009, 09:47 AM   #1 (permalink)
Crazyninja's Avatar
I Ride: '08 ZX6R
something my buddy did
he put castrol syntec in his bike (zx6r 636). it is oil actually for cars.
it is the energy conserving type. his bike so far after a 300 mile ride has did ok. i don't know what the long term effects are. he says his clutch is not slipping.
2008 ZX6R - candy plasma blue-stock battle axe tires, Healtech XTR-E, Gutted stock exhaust, PCIII - redneck tuned on an abandoned road-until the cops got called LOL
Crazyninja is offline   Reply With Quote
Old 06-17-2009, 10:34 AM   #2 (permalink)
On1Wheel's Avatar
I Ride: Black 2006 ZX6R 636
I don't think our clutches need special oil. I mean, I know it's a wet clutch but any engine oil is sufficient, right? I hope so because I run a full synthetic for cars.
On1Wheel is offline   Reply With Quote
Old 06-17-2009, 11:08 AM   #3 (permalink)
wrong wrong wrong.
Q: WILL AUTOMOTIVE OIL HURT MY CLUTCH?
A: Yes. The friction modifiers in motor oil improve fuel economy by making it easier for the gears, bearings, pistons and rings to slip, slide and turn inside the engine. Unfortunately, these friction-minimizing agents also make it easier for the clutch in a motorcycle to slip. If you are using automotive motor oil in your bike, apart from CRFs, you are losing hook-up and acceleration, as well as reducing the life of the clutch.
WILL AUTOMOTIVE MOTOR OIL HURT MY BIKE?
A: It could. If you're using an automotive motor oil in your racing four-stroke, you're not buying the best protection. An API SL oil is missing vital anti-wear components: the most common being zinc, phosphorus and sulfur. These agents are harmful to the catalyst that is used to diminish the level of pollutants in automobile exhaust.
Q: WHY ARE MOTORCYCLE SPECIFIC OILS BETTER?
A: Motorcycle specific oils are pumped up with five times the anti-wear, anti-scuff and extreme pressure additives of regular motor oil. As an added plus, motorcycle oil does not include molybdenum disulfide and other friction modifiers that wreak havoc on clutch performance.
Maxima, a popular motorcycle oil supplier, starts with an API SG Service Category base oil, the last formulation that wasn't regulated as to the amount of zinc-dialkyldithiophosphate (zinc, phosphorus and sulfur) it could contain. Maxima then boosts protection through a proprietary mix of performance additives. The end result is a motorcycle oil that doesn't break down under extreme heat and is tough enough to cushion meshing gears.
Morro Bay Rider is offline   Reply With Quote
Old 06-17-2009, 02:41 PM   #4 (permalink)
Originally Posted by Morro Bay Rider View Post
wrong wrong wrong.
well you looks like you know alot about oil.personally i think motorcycle specific oils are all b.s. i ave 3 zx11,s and i run mobil 1 car oil in all 3. the one zx is a drag bike that runs 8:80,s @155 on motor and i have never hurt a clutch yet. bike leaves at 7000 rpm with a 1.32 60 ft time. no the clutch is not slipping. oil does its job. i also put this oil in customers bikes and they don't have any issues. maybe the guys that have problems don't know how to launch a bike or the clutch is on the way out already. just my 2cents.
ninja11zx is offline   Reply With Quote
Old 06-18-2009, 02:05 AM   #5 (permalink)
Hammerhead's Avatar
I Ride: '04 ZZR 1200
You are fortunate most synthetic car oils do not contain the mileage-enhancing friction modifiers that cause wet clutches to slip. Motorcycle-specific oils contain anti-shear additives that prevent viscosity breakdown caused by transmission gears meshing. Even a blind squirrel gets a nut now and then.
Old 06-21-2009, 09:08 AM   #6 (permalink)
Site Sponsor
Amsoil Dealer Group's Avatar
First off, you don't say which Mobil 1 you are running. Mobil 1 is a company, not a product and they produce petroleum, hydro-cracked and some PAO Products although the Mobil 1 EP is now coming back from analysis as a Hydr-Cracked Product.
As far as a I know, Mobil 1 Racing 4T and their V-Twin oils are still PAO Based ...
Most manuals will say that an Automotive oil can be used as long as it has one of two requirements, It must carry a API SG/SH Rating and/or JASO MA Rating.
An SM, SL or other, Does Not Automatically Supercede the SG/SH Rating. They can carry both, but it must be listed on the label.
There is definitely something to Mobil 1 Auto oil when used in a bike and it is a case by case basis. Some slip, some chatter and this may happen over time as the oils are not made to clean off from the wet clutch and will get a varnish buildup. This has also been noted when switched away from M-1 to other oils and the next oil was blamed.
All oils have some type of Friction Modifiers, just some are not as detrimental to the clutch, which I think you are saying. With an SM oil, I don't think there is one oil out there that will carry the SG/SH Rating or JASO MA Spec.
You are correct about the shearing characteristics of the oils. Add a little soap to your oil and you almost have a grease making machine.
Some oils may use polymers as a Viscosity Improver and your transmission is quite a bit like a Centrifuge that may seperate some polymers out of the oil and can cause shifting problems.
Take a look at the G-2156 Link in our Sig. Some oils do better than others for storage with higher TBN and anti-rust and corrosion inhibitors, shear, foaming and wear than others.
Pick one of the Top 3 Finishers in the proper viscosity range and you will have a good oil.
Bob
Forum Members contact us for pricing shipped from the closest AMSOIL warehouse. For more info go to www.bestoil4you.com or call Toll Free 1-877-356-6099.
Motorcycle Oil Tests White Paper: http://bestoil4you.com/files/g2156MCoilStudy.pdf Gear Lube White Paper: http://bestoil4you.com/files/g2457GearLube.pdf
Amsoil Dealer Group is offline   Reply With Quote
Old 06-21-2009, 06:32 PM   #7 (permalink)
Well Bob , i also like ams oil. i do run the motorcycle stuff and the bike will pick up a couple tenth's over the mobil. i'm sold on both brands.
Old 06-22-2009, 05:05 AM   #8 (permalink)
Site Sponsor
You won't go wrong with either one. Just stay with the M/C Specific..
Old 07-06-2009, 04:52 PM   #9 (permalink)
zaneyzrex's Avatar
I Ride: 2000 zrx1100
long as its NOT energy conserving u should be ok.
crazy i think ur buddy is messin with ya or miss read the bottle
Old 07-06-2009, 07:02 PM   #10 (permalink)
Site Sponsor
Actually, it goes beyond that...
Look for the API Rating(s) od SG/SH and/or the JASO Rating of MA or MA 2
Sj,Sl or SM DO NOT automatically Supercede SG/SH
Bob
Old 07-06-2009, 08:51 PM   #11 (permalink)
zaneyzrex's Avatar
Thumbs up
Bob
not diagreeing but if you need some in a hurry then ya only need to worry about NO ENERGY CONSERVING
Old 07-07-2009, 04:02 PM   #12 (permalink)
Site Sponsor
There is way too much information and much of it from the internet and mechanics or parts people that do not study oil. This has been my business for over 25 yrs now.
It needs to have an SG/SH Rating to qualify for use in a Motorcycle if you have a Wet Clutch.
That Energy Donut does not cover some of the new Friction Modifiers on the market.. That is like all the stuff started about Moly, most of which is BULLoney.
Bob
Old 07-08-2009, 11:04 AM   #13 (permalink)
Crazyninja's Avatar
I Ride: '08 ZX6R
The crazy thing is that the average consumer does not have the "laboratory" to test and if you test on your own "investment" (your bike) and it goes wrong, its going to cost you a lot of money for your "lab results".
Old 07-08-2009, 06:02 PM   #14 (permalink)
Site Sponsor
That is why you look at our Motorcycle Oil Tests which are done by Several of the Top Testing Facilities in the US.
Also why you DO NOT listen to Joe Biker about using this or that oil.. He doesn't have to pay for your repairs.
Bob
