AMSOIL 10W-40 will handle low and high temp situations for you..
AMSOIL EAOM-103 should be the filter..
We have all the necessary fluids....
If you don't know when the brake system was last bled, I would Highly recommend that it be done..
You CANNOT See bad brake fluid and can lose up to 40% of your braking efficiency in 2 years
Therefore, it is recommended that brakes be bled every year and a system flush the following year..
We carry DOT 3 High Performance and DOT 4 Racing Fluids
http://bestoil4you.com/files/g2476BRAKE_FL.pdf
Bob
