Originally Posted by sexyc
I need someone to tell me the different between amsoil synthetic motorcycle oil vs. amsoil synthetic scooter oil except for the price which about 3.00 a quart. if there is no different i would to use the scooter in my zx-14. thanks for looking
The Scooter oil is designed to run in lower HP applications of a Scooter just for starters. It does not require as heavy an additive pack which is what you are paying for in the MCF.
They make different oils for different applications.. the difference is $2.30 cents per qt.
If you want to save $7.00 on an oil change and if your engine blows up due to an oil failure and not have a warranty, Have at it.
Personally, I run the AMSOIL MotorCycle Specific... Save under $10.00 on a change vs: $8000.00 for an engine... Not worth it ..
