» Insurance
GoFreeCreditReport
Old 12-04-2008, 10:12 PM   #1 (permalink)
jeffsbaum9er's Avatar
I Ride: 2000 zx 9 e1
race or not
hey all does any one have a suggestion for a good brake fluid to use for a 2000 zx 9 I'am tired of using the crappy cheap stuff also in process of putting stainless steel cables on any help would be appreciated thanks
jeffsbaum9er is offline   Reply With Quote
Old 12-05-2008, 04:56 AM   #2 (permalink)
Hammerhead's Avatar
I Ride: '04 ZZR 1200
Any good brand of DOT 4 spec brake fluid should do. I doubt if you can use DOT 5 without risking damage to seals in the calipers and master cylinders.
Old 12-05-2008, 08:17 AM   #3 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R,KX125
motul rbf 600 is good stuff. you'll have to change it out a little more often than normal though. that and steel lines are more than enough stopping power for most people.
Cat cut out
Emissions removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Driven Sprockets -1 +2
Vortex clip-ons
Vortex rearsets GP shift
PowerBronze DB windscreen
Ohlins ZX10 steering stabilizer 45wt oil
Hyper Co rear spring
Sato front axle sliders
Old 12-10-2008, 06:29 PM   #4 (permalink)
race or not
hey thanks for the help , i was recommended a race fluid named wagner 5.1 the salesman said it is mixable with dot 3 &4 did either of you guys here of it considering the motul rbf 600
Old 12-10-2008, 10:47 PM   #5 (permalink)
SLIDER's Avatar
never heard of it. I'd be careful putting anything over DOT4 in though, even if it is compatible.
Cat cut out
Emissions removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Vortex clip-ons
Old 12-14-2008, 04:55 PM   #6 (permalink)
valvoline synthentic dot4...cheap, available at any autoparts store and very good boiling point.
the dot 5 silicone stuff blows....don't use it.
jbreit is offline   Reply With Quote
Old 12-22-2008, 11:49 AM   #7 (permalink)
kdankenb's Avatar
valvoline synth is good, or if you want to go all out and splurge, get castrol SRF.. at $80 a quart.. it is the absolute best.. with the highest boiling point and lowest numbers on compression
Zen Motorcycle
Parts - Performance - Service
480.600.2978
www.zenmotostore.com
Owner
"all the - Go Fast - parts your bike will love"
kdankenb is offline   Reply With Quote
