BikeBanditRacer Parts WholesaleMotorcycle.comJazzMotorsports.comMotorcycle.com Classifieds!5150 ConceptsAdvanstarMotorcycleShowsSportbikeTrackGearATV.com
JazzMotorsports.com
Old 08-11-2008, 09:16 PM   #1 (permalink)
I Ride: 1994 ZX-11
Oil Light - not on?
For as long as I have had the bike, oil light comes on before start-up...normal. Now for some reason it doesnt come on anymore at that point. Any reason? I cant seem to find anything about it in the manual. I have 94 zx11
ArizonaZX11 is offline   Reply With Quote
Old 08-12-2008, 12:46 PM   #2 (permalink)
If when you turn your ignition on but havnt started the engine and your oil light isnt lit up it means one of three things:
1- your battery is flat (stupid suggestion but i mention it anyway)
2- you got a blown bulb or fuse
3- the oil pressure switch is broken/stuck in the pressurized state
Tenquo is offline   Reply With Quote
Old 08-12-2008, 03:16 PM   #3 (permalink)
I Ride: 1994 ZX-11
if its case 3, how do I know/check, and how do I fix it
Old 08-13-2008, 02:20 PM   #4 (permalink)
To check if its the pressure switch you need to first find it and unplug it then turn on the ignition and try grounding and ungrounding the live wire and see if you can light up the oil light, i dunno how its done on the zx11 but ive seen switches where you have one wire which needs to be earthed to work and versions with two wires which you simply connect together.
If you can turn the light on this way it means that the switch is probably the problem, after that only real solution is swap it for a new one from kawa.
Old 08-13-2008, 02:45 PM   #5 (permalink)
I Ride: 1994 ZX-11
thanks for your help. Is there any easy way to just to just check to see if the bulb itself is good? I want to get to the bulb but I need a way to test it
Old 08-14-2008, 10:59 AM   #6 (permalink)
I Ride: 1994 ZX-11
ok the connector by the shift pedal was loose. Thanks for your help!
Old 09-05-2008, 11:53 AM   #7 (permalink)
I Ride: 1994 ZX-11
nevermind...same problem back again...does it happen to do this when the pump has gone bad?
