BikeBanditSpringfield ArmoryATV.comRacer Parts WholesaleJazzMotorsports.comMotorcycle.comCheapCycleParts.comAdvanstarMotorcycleShows
JazzMotorsports.com
Old 07-27-2008, 11:10 PM   #1 (permalink)
oil light on!!!!
07 zx14 full yoshi, pc3, k&n air, flies out.
last night , jumped on the highway, accelerated really hard all the way up to 150mph and noticed the oil light was on. i immediatly pulled the clutch and rolled to a stop and turned off the bike. i checked my oil level, which was perfect, and cranked back up. light came on again, so i shut it off. waited about five minutes, cranked back up, no light, so i headed back home. my question is what could have caused this? my oil level was good. i dont know how to check oil pressure, and if it was an oil pressure issue, why did the light stay off the second time. hopefully this is just an error on the comp. part or a sensor malfunctioning. i did have one worry, while tightening a wellnut that holds the tank cover. the rubber wellnut broke and fell into the frame. as you fellas know, the frame is the airbox. so had to remove the tank, open airbox, and found the nut laying by the intake ports. could a small piece of rubber possibly been sucked in and somehow clogged up in an oil passage? and when i do say small i mean small because i did not see it when i recovered the main piece
steve-o is offline   Reply With Quote
Old 07-28-2008, 01:00 PM   #2 (permalink)
Mister Ecua's Avatar
I Ride: 07 ZX-10R
I don't have any technical advice for you, but if your oil light came on you don't need to ride your bike any more until you have resolved that problem, you can cause some real engine damage. Hell, if you see your oil light come on while riding, you need to stop and call a tow. Just speaking from experience...
Mister Ecua is offline   Reply With Quote
Old 07-28-2008, 05:38 PM   #3 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R,KX125
don't worry, there's no way for the nut to find its way into the oil passages. Actually, it won't even get passed the air cleaner unless you have a hole in it. I'd suggest taking the bike in to have it checked out. you could have a couple clogged passages, a bad oil pump or a bad sensor... who knows. you don't want to destroy your engine because of oil starvation.
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets reverse shift
PowerBronze DB windscreen
Hyper Co rear spring
Sato front axle sliders
Old 07-29-2008, 04:29 PM   #4 (permalink)
well the bolt did fall on the inside if the air filter. on the 14, theres bolts on the frame, bad thing is that the frame is the airbox an both sides of the filter. but i did get the nut out. i was just thinking worst case scenario. if i might have missed something.
Old 07-29-2008, 04:47 PM   #5 (permalink)
SLIDER's Avatar
oh yeah... forgot about the frame design of the 14. at least you got the nut out.
2007 ZX6R
PCIIIUSB custom map
Jumper Mod
BMC race filter
Vortex clip-ons
Old 08-12-2008, 01:46 PM   #6 (permalink)
Like everyone one else said....ive seen low viscosity oil, faulty oil pressure switches, faulty pumps and the plain old "oil sloshing to the back" causing problems on bikes with no problems engine oil wise.....
Freind has a kawasaki er-6n (ninja 650r to you guys) and he had enough oil (ok not right up and level with the max.), but problem was that under really hard braking his light would light up because the oil sloahed away from the oil syphon and the pump started sucking up little bits of air.
Another freind had oil which had somehow mixed with his gas on an old suzuki, oil level was fine but oil was so fluid the oil dropped below the switch's threshold and the light came on.....
Get a kawasaki mechnic to have a look, they should be able to hook up a barometer to check the oil pressure at different temps and engine speeds and compare it to kawasaki's specifications.....
Tenquo is offline   Reply With Quote
