SuperbikeToyStore.comAdvanstarMotorcycleShowsSpringfield Armory5150 ConceptsJazzMotorsports.comSportbikeTrackGearRacer Parts WholesaleMotorcycleToyStore
Old 05-31-2008, 09:57 AM   #1 (permalink)
95zx6's Avatar
Should I pay to have my oil changed or do it on my own?
I was wondering about this. I change my oil on my car. But I was reading the manual, it says its pretty easy, but do I really need to replace some of the washers and o rings? You have to take the oil cooler off too. Its a 95 zx-6....definitely needs an oil change. Also what kinda oil should I use, just Mobil for motorcycles or something?
I also do not have an oil filter wrench (unless it is just a socket wrench and not a specific tool) and I have no center stand....I take it that makes it difficult or what?
95zx6 is offline   Reply With Quote
Old 05-31-2008, 11:27 AM   #2 (permalink)
uzimon's Avatar
the oil cooler issue would keep me from it, for sure.
on no bike i've had since 2000 (except on busa's that needed fairing loosened to get filter out ) have you had to do anything but drain the oil, pull filter, replace filter and refill.
haven't had to replace the drain plug o-ring either, just when the nut got rounded off from using the stock tool kit. a socket wrench with a 17mm is best
uzimon is offline   Reply With Quote
Old 06-08-2008, 09:53 PM   #3 (permalink)
ZuluNinja's Avatar
I Ride: '07 ZX-14, '86 Honda VFR 750 & '03 Nissan 350 Z
a stand is not necessary, but makes it easier. Socket wrench is a must if u don't want to wrestle with a screwdriver stabbed thru the middle of the filter. Go to a dealer and get some good synthetic oil; I did my zx6r some time ago with synth for cars and it foamed, so get bike oil. Apart from that, it should be a fairly easy DIY, the washer is pretty solid and good enough for a some changes; dealers around here charge 60$ for regular oil change, synth can go above a 100$, if u get the oil and filter it's around 30-40 bucks depending what u get.
Captain of the Black Z's
ZuluNinja is offline   Reply With Quote
Old 06-14-2008, 08:16 PM   #4 (permalink)
95zx6's Avatar
what about removing the oil cooler, easy?
Old 06-16-2008, 09:10 AM   #5 (permalink)
RedneckHillbilly's Avatar
I Ride: 06 ZX14
I've never replaced a drain plug washer, ever, on anything.....why does the oil cooler have to come off ?
Help control the squid population, have your squid spayed or neutered
Jester
RedneckHillbilly is offline   Reply With Quote
Old 06-16-2008, 12:09 PM   #6 (permalink)
95zx6's Avatar
apparently to change the oil filter on the zx6
Old 06-16-2008, 05:06 PM   #7 (permalink)
I Ride: 06 ZX14
its in front of the oil filter ? just take it loose but dont take the lines off it, maybe, I cant see it from here...
Jester
Old 06-18-2008, 05:13 PM   #8 (permalink)
I Ride: 1988 ZX-10 Ninja
Do your own oil/filter change ?
I've got an 1988 ZX10 that I'm going to do an oil / filter change on very soon . The bike has a Hindle pipe with no centerstand .
The pipe snakes directly under the oil filter housing , therefore it must be removed to drop the filter . I purchased new copper exhaust gaskets from the dealer ( $ 45 w. tax ) and I'm pretty sure I'll have to move the oil cooler and possibly the rad to get the pipe out , but I don't know yet , until I get into the job .
The oil filter hasn't been changed in a while according to the previous owner . If I had the dealer do it , they add $ 50 to the oil change bill , if the pipe has to be removed .
If you have good mechanical skills / tools , have a manual and are careful about putting everything back in the same order as disassembly , you'll have NO problems and you'll get to know your bike more intimately and build your confidence level to take-on other maintenance tasks , ( ie. valve shimming ) !
The ONLY person who will take the time , be clean , be careful and ensure the job is done right is YOU !
BTW , the K&N oil filter comes with all the necessary o-rings for filter replacement .
Joe88ZX10 is offline   Reply With Quote
Old 06-28-2008, 09:46 PM   #9 (permalink)
95zx6's Avatar
I finally changed my oil. It wasn't too bad to get to the filter either. Taking the fairing off is annoying, even worse putting it back on (probably because mine is a little beat up). The oil cooler does not need to be disconnected, there are just 3 bolts holding it on and you can undo those and move it out of the way. The headers surround the filter pretty tight but I managed to fit my hand in there to unscrew it.
I actually have a minor leak where the shifter comes out. Not sure if I am going to fix it as it seems like a lot of work. Anyway thats all for now.
Old 07-18-2008, 12:26 PM   #10 (permalink)
Good work 95ZX6 !
Old 08-13-2008, 02:29 PM   #11 (permalink)
I take that as an insult!
Tenquo is offline   Reply With Quote
Old 08-20-2008, 09:57 AM   #12 (permalink)
Just trying to instill artificial confidence in the NooB ! No offence to the Kawasaki line mechanics !
Old 08-20-2008, 03:03 PM   #13 (permalink)
I Ride: 06 ZX14
Swiss Kawasaki line mechanics
Jester
