Hey man don't follow kawi 's breakin !!! It is the "responsible" company way , you need to get those piston rings seated and that way isn't gonna do it .First of all NO redlines until at least 600 miles , don't ride at a constant speed, and keep that bike loaded and unloaded . You don't need to WOT the bike when you are accelerating but accelerate and let off WITHOUT the brakes let the engine work itself down . Do this as much as you can for the first 600miles . I would also do an oil change and filter at about 100 miles and again at 600 .
Full Akra EVO Ti (shortened pipe)
pcV with autotune
-1 front sprocket with healer
Woodcraft sliders
Hotbodies GP windscreen
Homemade fender eliminator
modified chain guard
X TRE
Zip tie mod
Factory Ohlins damper mod
Kleen air mod
Pazzo levers (green adjuster)
Spiegler brake lines
K&N air filter
And a few secret weapons
