Bike's starter motor won't run sometimes
I just got this bike, 01 zx6r, and i've had it not want to start on me twice in the last 2 weeks. I'll go to hit the starter switch and it won't do anything, no noises at all. The first time i did it i just hit it a couple more times and then the bike started up. Last night when it did started messing up again, that if i pulled the clutch all the way down to the grip it would go but not if i used the 2 finger pull. When this happened i figured the cable needed to be adjusted but later that night i was able to start the bike without the clutch even pulled. I thought just like a car, the bike isn't supposed to start without the clutch pulled. What do you guys think?
Oh and last night i started having problems shifting past 3rd, it would take me a few trys before it would shift. I don't know if the two are related or if it helps any.
