Motorcycle.com Classifieds!Springfield ArmorySuperbikeToyStore.comRacer Parts WholesaleCheapCycleParts.comJazzMotorsports.comATV.comMotorcycleToyStore
Old 01-26-2008, 08:20 AM   #1 (permalink)
xxxdesigns's Avatar
I Ride: 2007 RED ZX6-R
Question 07 zx6r oil filter removal
Plan on doing my own oil change soon ,what`s the best way to get the oil filter out? It`s in a really tight spot.
xxxdesigns is offline   Reply With Quote
Old 01-26-2008, 08:37 AM   #2 (permalink)
Alpr22_07 Zx6's Avatar
I Ride: 07 Zx6 -Lime Green
use a pluming wrench big enough to grip the filter squeeze it and turn it other wise you gotta buy the tool which will cost you around $40 or sumthing like that. then install and k&n oil filter they have a nut so you can use a wrench next time.
Alpr22_07 Zx6 is offline   Reply With Quote
Old 01-26-2008, 09:06 AM   #3 (permalink)
xxxdesigns's Avatar
thanks! where did you get your k&n for the 07?
Old 01-26-2008, 09:26 AM   #4 (permalink)
xxxdesigns's Avatar
Oh, i found one.
Old 02-03-2008, 09:45 AM   #5 (permalink)
rjking's Avatar
Changing oil filter
I had to buy one of those cheap stamped oil filter wrenches from AutoZone and use 5 minute epoxy to "glue" it to the oil filter to get it out. Once you get it out use the K&N filters from now on...
RJK
rjking is offline   Reply With Quote
Old 02-03-2008, 11:23 AM   #6 (permalink)
ZX^R PARKZ's Avatar
I Ride: ZX6R 07 NINJA (ORANGE)
just did my oil filter, conventional oil filter wrench did the job nicely!!
ZX^R PARKZ is offline   Reply With Quote
Old 02-04-2008, 04:27 AM   #7 (permalink)
Jester's Avatar
I Ride: ZX10R SE
the factory oil filter is a pain in the arse but it get's easier after that!
I had to punch a long screw driver through it to get enough leverage budge it. Just remember to put a newspaper over the headers to funnel the leaking oil down to the oil tray! Just a tip!
Jester is offline   Reply With Quote
Old 02-06-2008, 07:30 AM   #8 (permalink)
DuckyZX10R's Avatar
I Ride: 2007 ZX10R SE
on the tip. I did screwdriver trick as well and I got some oil on the header. Even though I had wiped it down real good, it still "smoked out" from the burning of oil on the hot pipes. No big deal really after the oil burned out but its always better to avoid that situation in the first place.
2007 ZX10R SE - Akra Twin TI Bolt-ons, PCIII, K&N Filter, LSL Frame Sliders, Competion Werkes Fender Eliminator Kit, PUIG Dark Smoke Windscreen, GIPRO w/ATRE, Galfer SS Braided Lines, EBC HH Brake Pads
DuckyZX10R is offline   Reply With Quote
Old 02-08-2008, 05:21 AM   #9 (permalink)
Jester's Avatar
I Ride: ZX10R SE
^^ good to hear from you again Duck (sorry for the thread jack)
Old 02-16-2008, 01:04 PM   #10 (permalink)
just shove a screwdriver in it wont hurt anything
dirtboy is offline   Reply With Quote
Old 09-10-2008, 10:02 AM   #11 (permalink)
I Ride: 2007 Kawasaki Ninja ZX-6R
Thumbs up
thats what i did. you dont need the oil filter anymore anyway. i didnt even have a big mess
DuskNinjaRider is offline   Reply With Quote
Old 09-12-2008, 11:13 PM   #12 (permalink)
I Ride: '08 ZX6R
I used one of those cheap $5 stamped oil filter tools too. It worked fine.
Oil spills all over your engine and down the inside hoses and fairing. It really sux since I like to keep my stuff clean.
I am going to devise a punch tool that has a large hollow needle with a tube attachment to punch and drain the oil filter before it is screwed off.
I am going to take a piece of brass like a brass T of some sort and sharpen the end of it, connect a drain tube to the 90 degree part, then weld up the other open end so it can be struck with a hammer.
You could then put the tube in a container, put the homemade needle type device near the bottom of the end of the oil filter, tap it in with a hammer and drain the filter before you screw it off.
2008 ZX6-R, K&N filter,8000K HID (15 more hp) Jumper Mod, PCIII, Gutted stock muffler (Hillbilly slip-on) w/ butterfly valve removed. Rear fender removed w/plate on swingarm.
Sirius sat radio, Bell radar detector (both worth 10 rwhp gain) Listening to Sirius 20 rockin down the highway
Crazyninja is offline   Reply With Quote
