Well, I have an answer, sorta. I had the same problem with an old KZ I have. Had no key. I took a nail file because it was thin enough to fit down in the key tumbler (if thats what you call it, you know what I'm talking about). I ground it down really thin and skinny/narrow with a little hook on the end. The tumbler itself is a seperate piece that locks down inside a barrel that is a seperate piece. Inside the slot where the key goes is a little release button somewhere that allows the tumbler to be pulled out of the barrel. I felt around in there for a while until I found the release button, pushed it in with the little hook, it released, then I used the hook to pull the whole tumbler out. With the tumbler out the bottom of the barrel just had a slot in it that could be turned with a screw driver, pocket knife, whatever. Now I'm not sure what bike you have and its probably not as basic as an old KZ (which is about as basic as it gets), but I believe that every ignition switch has a release and can be pulled out of the barrel if you can just figure out the right tool and manage to hit the release and pull it out.
Quote from a Kaw mechanic (my dad)
"Great idea, buy your kid a ninja for his last birthday."
