Originally Posted by ZXdan
I generally find that most mechanically minded people will have a good idea of whether a sound is bad, or real bad when you listen to it.
I find they usually turn out to be full of shit. Kawasakis make noise. The 250 is much easier to work on the any of the 4 cylinders, and cheaper. There's a lot of room around the engine to do whatever you have to. Get a manual. If you get a chance try to listen to more Ninjas; you'll find most make weird noises.
