89 zx600 jetting? - ZX Forums
post #1 of 4 (permalink) Old 05-29-2012, 09:44 PM Thread Starter
89 zx600 jetting?
i have an 89 zx600 that i have been working on for a while. i removed the airbox to do cheap pod filters but cant quite figure out the jetting. i have 132.5's in the carbs now and on a cold start up if i try to rev it, the bike just dies. if i wait for it to warm up to running temp it runs pretty good but it still has some bogging issues in higher rpms and the exhaust smells horrid. half way to running temp if i hold the throttle back it bounces between 2k and 5k rpms about 10-15 times the finally revs up.
does this sound like i need to go larger on the jets? im thinking im not quite getting enough fuel. does anyone have a similar setup? what jets are you running?
carbs are synchronized perfectly, rebuild kits through all of them, factory exhaust and factory cams, brand new spark plugs. the only thing i changed is the airbox to pod filters.
Connella08 is offline
post #2 of 4 (permalink) Old 06-03-2012, 10:56 AM
On my b ike, similar (-90) there is a set of vaccum-carbs. This type of carb need the STD-airbox to work. This is because they work in pressure difference, you do not lift the thottle via the cable, it is controlled via (under-) pressure.
Removing airbox messes the pressure differences up, and all kind of problem appears.
If you do not believe me, put the STD-airbox back and test.
RalphSweden is offline
post #3 of 4 (permalink) Old 06-03-2012, 10:59 PM Thread Starter
i would but the boots on the factory air box were dried out and shrank, making it impossible to put on the backs of the carbs. i got them to go on at one point, but eventually popped themselves back off due to the rubber being too hard.
post #4 of 4 (permalink) Old 06-21-2012, 01:45 PM Thread Starter
i decided to clean my carbs yesterday and found a bunch of junk in the bowls. blew them all out and it runs much better. it stumbles a lot when cold, but only hits a minor flat spot when completely warm. do you think maybe i need to go up or down a jet size?
Human Verification
