start problem help - ZX Forums
post #1 of 13 (permalink) Old 10-19-2010, 07:52 PM Thread Starter
start problem help
i have a zxr 750 ninja 1993 ,,, it wont start , it has a clicking noise coming from igniter box , thats all iam getting ? does anyone have any clues ? :
wowie is offline
post #2 of 13 (permalink) Old 10-19-2010, 08:06 PM
MadKawi636's Avatar
I Ride: 05 636 Kawi green
check your battery terminals see if their on tight or do a voltage check on the battery good luck
MadKawi636 is offline
post #3 of 13 (permalink) Old 10-19-2010, 10:11 PM
whitehendrix's Avatar
I Ride: all sorts of shit.
dead battery
i build race engines
i am an electrical engineer
i is smart
Sir Turbo Fabbin, Guitar Shreddin, Lunatic Red Headed Crash and Burn Whore of ZXF
I agree. (with whitey)
whitehendrix is offline
post #4 of 13 (permalink) Old 10-20-2010, 03:39 AM Thread Starter
battery is ok
battery is fine , terminals are good , even used jumper pack ,any other clues
wowie is offline
post #5 of 13 (permalink) Old 10-20-2010, 03:10 PM
starter solenoid shit the bed. that or the control relay powering it. that, or the button powering the control relay.
jump the solenoid out with a screwdriver.. see if it cranks..
yes?-->test voltage to solenoid, work backwards from there
no?-->test starter.
i is smart
post #6 of 13 (permalink) Old 10-20-2010, 03:39 PM Thread Starter
thankyou i will try this and go through it cheers ,,,,
wowie is offline
post #7 of 13 (permalink) Old 10-21-2010, 07:24 AM
sportryder's Avatar
I Ride: 04 zx6r
your sure the clicking is from the ignitor box and not the starter solenoid? does the engine crank? all you said was it won't start. if the starter solenoid is clicking then it won't crank. im just trying to understand if you got your parts mixed up, no offense.
sportryder is offline
post #8 of 13 (permalink) Old 10-22-2010, 06:53 AM Thread Starter
no worries , yes the startor solenoid is ok , i crossed the terminals , i started the bike with a direct wire from battery to starter, when i use the starter switch on the throttle all i get is a click from the igniter box thats it , nothing more ,, hey no offence taken , all cool ,
wowie is offline
post #9 of 13 (permalink) Old 10-22-2010, 11:57 AM
either a failed coil in the solenoid, or the control relay i the junction box took a shit. it is a 5A MR301 form 1-C dry reed relay..SPDT
meter power at the solenoid.. these bikes have a tendency to start dropping 4-5 volts along the starter control circuit and the resulting 7V getting to the solenoid isn't enough to actuate it.
i is smart
post #10 of 13 (permalink) Old 10-23-2010, 03:07 AM Thread Starter
oh ok , so where is the junction box ? is it the igniter box ? that holds fuses as well ? bcos thats where the clicking noise comes from ?, what do i need to replace to fix this problem ? do i need another igniter box ?
wowie is offline
post #11 of 13 (permalink) Old 10-23-2010, 05:59 AM
slim1100's Avatar
I Ride: 1998 ZX9R & 2007 ZX10R
welcome to zxf... sry cant help u .... but these guys know what they are talking about ^
Sir Throttle Twistin, Roo racin, Outbackin Post Whore of ZXF
Originally Posted by Dieseld13
I can't believe pastacio nuts are legal. Phuckers are highly addictive
Originally Posted by rrzxter
Soooooooo, until someone comes up with a better solution,......... crop dusting with birth control
slim1100 is offline
post #12 of 13 (permalink) Old 10-23-2010, 08:00 AM
junction box is where your fuses are. theres a small control relay in there that feeds power to the solenoid.. but for some reason, they way they feed the power, many many times it develops a voltage loss along the way.
shouldn't need to replace the CDI. it's a separate piece altogether.
i is smart
post #13 of 13 (permalink) Old 10-26-2010, 02:57 AM Thread Starter
oh ok thanks whitehendrix will know tomorrow whats happenen , as i will replace the juntion box then cheers
wowie is offline
Human Verification
