Wiring for 89 Ninja ZX750 H1 - ZX Forums
post #1 of 13 (permalink) Old 08-25-2010, 07:43 PM Thread Starter
Hi all, I just bought an 89 ZX7 with some electrical issues. It wasn't till right after I paid for the bike that the problems started when I tried to start it to ride it home. When I pressed the start button, the small wire going to the solenoid got hot and started to smoke. I ended up putting the bike in a van and brought it home. I think someone may have used a solenoid that is for a different bike which is why some of the wires have been mickey moused. It appears that they ran their own wires from the start button up on the handlebars to the solenoid rather than going through the wiring harness. I have cut off the "added on" wires and reattached the stock green connector to the end of the wires on the start, off/run buttons, but do not see where to plug it in, I just know that it connects somewhere near the front of the bike by the length of the wires. I also do not know where the small wire for the solenoid goes, I just know that it must connect into the main wiring harness somewhere. Is there a manual or pictures on the web somewhere that would have actual pictures of these, the connectors, and where they plug into rather than just a wiring diagram? Wiring diagrams confuse me and I have a hard time trying to figure them out. I would like to ride the bike before the summer is over. thanks in advance.
medicinalmotorcycle is offline
post #2 of 13 (permalink) Old 08-25-2010, 08:17 PM
2fat2fly's Avatar
Garage
This might help:
My Turbo ZX12R Build:
My 1993 ZX7R (M1)
2fat2fly is offline
post #3 of 13 (permalink) Old 08-25-2010, 08:23 PM
90zxr750's Avatar
I Ride: 2004 zx10r & 2007 Vulcan mean streak
Garage
damn i coulda used that diagram 6 months ago
Sir Dino Ridin, Acoustic Smasher Punk Whore of ZXF
2004 zx10r
1990 zx-7 SOLD march 2012
90zxr750 is offline
post #4 of 13 (permalink) Old 08-26-2010, 05:14 AM
2fat2fly's Avatar
Garage
Didn't know you needed one.
My 1993 ZX7R (M1)
2fat2fly is offline
post #5 of 13 (permalink) Old 08-26-2010, 11:52 PM Thread Starter
Thanks for posting the wiring diagram 2fat2fly, it should come in handy in the future when I learn how to read it. Am I the only one who can't read wiring diagrams? At this time, I really just need to know where the connector for the start, off/run buttons plugs into. Is it somewhere right behind the headlights or underneath the gas tank?
post #6 of 13 (permalink) Old 08-27-2010, 03:51 PM
kawa kid's Avatar
It's under the gas tank. There should be 6 wires coming from the run/off switch that are attached to a green connector. That green connector plugs into the other green connector, which should be located under the gas tank.
kawa kid is offline
post #7 of 13 (permalink) Old 08-28-2010, 04:14 AM Thread Starter
Ok, sounds like some good info Kawa kid. I found 6 wires together under the tank coming off the wiring harness which had the connector cut off and weren't connected to anything. These must be the wires I need to connect into. If I had the connector for the harness, I could just re-attach it and connect the 2 green connectors together, but I don't. So I'm thinking about putting my own connectors on each individual wire and connecting them that way. Problem is the colors of the wires on the harness are not all the same as the colors of the wires on the start, off/run buttons, so I am not sure which wires to connect together. I looked at the wires and took some notes, here they are:
Wires on Start, Off/Run Buttons, Brake light switch:
Black w Red tracer - Start
Yellow w Red tracer - Off/Run
Red - Off/Run
Black - Brake light switch
Harness:
Black w Red tracer
Blue w Red tracer
Brown
Red
Red
Yellow
Any idea which wires coming from the buttons to connect to the wires on the harness?
post #8 of 13 (permalink) Old 08-28-2010, 03:51 PM
kawa kid's Avatar
Ok,
From the harness Blue/Red tracer to Black.
From harness, black/Red tracer to Balck/Red tracer
From harness, Red to Red
From harness, Brown to Black
From harness, Yellow to Yellow/Red tracer
kawa kid is offline
post #9 of 13 (permalink) Old 08-28-2010, 04:03 PM
kawa kid's Avatar
I haven't done this yet but her is the first attempt.
http://s982.photobucket.com/albums/a...view=slideshow
kawa kid is offline
post #10 of 13 (permalink) Old 08-30-2010, 04:04 AM Thread Starter
Ok, thanks for the info and picture Kawa kid. I am starting to get somewhere. I touched the blue/red tracer and brown wires on the harness together to see if the brake light would come on and it did, so I am on the right path. As far as the 4 other wires for start and off/run, I haven't been able to check those because I don't have the right solenoid, I need to buy the right solenoid for the bike. I looked at the album of your bike Kawa kid and discovered that the red connector for the solenoid has also been cut off from the harness on my bike which explains what those 4 wires with no connectors I see are for. I'm not too sure I can put my own connectors on those wires for the solenoid, I guess I won't know that until I have the solenoid and can look at it. You have an extra solenoid for the '89 ZX-7 you want to sell Kawa kid?
post #11 of 13 (permalink) Old 08-30-2010, 07:12 AM
kawa kid's Avatar
Sorry, I don't.
kawa kid is offline
post #12 of 13 (permalink) Old 12-19-2011, 04:18 AM
Thumbs up Ignition switch wiring...
Glad to see someone with a readable Diagram, Thank you for all the kawi ryders that have needed it. I tried to get by with a russian diagram and german one with little luck the last year until now. shortened my wire loom a ft-1/2 and revised my component placement for a saddle seat mod...
Problem is that i have had a tampered-with harness for yami controls and upgraded with HID bi-xenon and wireless keyfob, so then now i'm trying to figure the yellow wire (leading up from the killswitch) to??? Brown or white, or both (leading up from Junction box)?
By the looks of it on the German diagrams: Brown, Grey, and white, go to the key-switch... There's no grey wire in my whole engine circuit, or in the accurate one for my bike specific-to the start of this forum. I'm pretty sure the white wire switches my yellow wire for running the motor, Confused as to why brown would be on it? and if it runs through the switch to my kill-switch like the German diagram shows...
TradeM is offline
post #13 of 13 (permalink) Old 12-21-2011, 04:33 PM
http://imageshack.us/photo/my-images/526/igns.jpg/
ZX wont let it upload the image for the German diagram because its too big... untill thumbnail sized and unreadable.
This is the 87-90 zx750f which my bike has same motor and essentially the same electronics.
TradeM is offline
Human Verification
