Fuel Pump Problems - 95 zx6r
Hey guys, I recently put in a new motor on my 95 zx6r and am having troubles with the fuel pump. Everything was working fine before the motor swap (except for the spun bearing on the crankshaft...) but now with the new motor when i turn the bike on or try to start it the fuel pump wont run. It doesn't appear to be getting a signal as I checked the voltage to the pump and there wasn't any. Everything else is working fine (we got the engine to fire up and run for a little bit by manually running the pump) except for this, as far as we can tell. Does anyone have any ideas as to what could be causing this? All the fuses are good and there doesnt appear to be any damage to the wiring harness, so i'm out of ideas... thanks in advance for any help
