» Insurance
Motorcycle.comATV.com - Write Your Review and Win!BikeBanditMcCoyMotorsportsSportbikeTrackGear
Old 11-08-2009, 10:36 AM   #1 (permalink)
Connect Turn Signals
I went to the track on 10/26 NJMP. At tech inspection, I had to remove my mirrors on my 08' ZX-10r. I don't know how the disconnected the wires. I placed the mirrors back on the bike, but wires just hanging now :-(. Somebody help me. Send me a pic or describe where the wiring connect.
Thanks
RONDUKES52 is offline   Reply With Quote
Old 11-08-2009, 11:35 AM   #2 (permalink)
Administrator
Shifty1's Avatar
I Ride: 2005 ZX6R
There should be a small harness connection somewhere close to the mounts. It should only be two wires going into a small connector. They're in there somewhere, you just have to find them.
-Poetry written in gasoline.
Old 11-08-2009, 01:15 PM   #3 (permalink)
mmadrid74's Avatar
I Ride: '08 ZX10R
Post a pic if u can. I'm thinking they disconnected the mirrors at the harness under your gauge cluster. If so, u should have two connectors hanging out, a black and a grey. If that's the case, remove your windshield. Take two screws out of the base of your gauge cluster. The next part sucks because the rubber grommets that your winshield screws to have to be pushed or pulled out of plastic that forms upper part of the ram air. Very flimsy plastic. But, once you get passed that, you will find the two wiring harness's your looking for under the gauge cluster. Matching colors make connecting the blinkers back up easy.
Be warned - the plastic is flimsy and cracks easily. Probably easier to just push the rubber thru. Trying to pull them out will just break your plastic. Installation means pulling the rubber thru as gently as possible.
More warning - According to the service manual, the gauge cluster CANNOT be stored, rested, or left hanging on it's side or upside down. Make sure u leave it right side up once u move it out of the way. Idk what damage could occur, but I'd rather not find out the hard way.
Good luck. Hope this helps
It's against my religion to have a religion.
"Just 'cuz ya got the monkey off your back,
doesn't mean the circus has left town." - G. Carlin
Spiegler SS lines Pazzo Racing levers M2 Ti full exhaust Evotech tail tidy Pilot Power 2ct 156 blue LED glow kit LED turn signal bulbs Bazzaz TC controller
mmadrid74 is offline   Reply With Quote
