too much vacuum?
the kit recommends drilling the extra hole for the slide but I have been told its not always a good idea, too much vacuum can make the engine hesitate right off idle if the slides move to quickly, I worry about having enough gas flow to keep up with the air filter and pipe given the ram air causing the flat spot.
