» Insurance
ATV.com - Write Your Review and Win!BikeBanditMotorcycle.com Classifieds!SportbikeTrackGear
Old 09-20-2009, 12:08 PM   #1 (permalink)
stalls at idle
Hello, my brother has a 03 or 04 zzr1200 that has been sitting for two months. i drained the gas and put in fresh gas. started it up and only runs with choke on. i let it run till the fan came one so i know it was warmed up . took the choke off and stalled . checked plugs . looked good but put in new ones anyway . noticed that the spark was not a bright crisp one ? would that cause it not to run at low rpm ? if so what could cause the spark to be week .i fully charged battery and no change . tried seafoam also . now it will run with choke half way. when you go to give it throttle , stalls . please help. i want to get it going for him ,so when he comes back we can ride .
artie is offline   Reply With Quote
Old 09-20-2009, 02:57 PM   #2 (permalink)
e1_ZX-9r's Avatar
I Ride: 00 ZX-9r Lime Green
Only two months and now it runs like this? I've read about this exact problem on other carb'ed ZXs here. You could try searching to see how they were resolved. Without knowing the history of that particular bike, I think generally that the recommendation will be to drain and pull the float bowls off for a cleaning.
It's probably an obstruction in/with:
Pilot air screws
pilot jet
float needle sticking/blocked/fuel munge
jet needle/main jet
flat slides stuck
or something that was disassembled recently regarding vacuum/ignition/fuel
If you're familiar with carbs and a little mechanically inclined, you can buy some B-12 carb cleaner and blow the carb intake and jet holes out and verify if there was an obstruction somewhere.
e1_ZX-9r is online now   Reply With Quote
Old 09-20-2009, 08:50 PM   #3 (permalink)
zaneyzrex's Avatar
I Ride: 2000 zrx1100
its a carbed bike then the pilots are clogged.... pull carbs and clean pilots......
zaneyzrex is online now   Reply With Quote
