ZX9R Starter Issue
Hi all,
got a '95 ZX9R that needs to be put in gear, rolled backwards and the clutch popped in reverse to turn the motor before the starter will engage while starting. The problem is intermittent. At times it starts as if there's no problem at all. When the problem is present, the starter will draw current but the engine doesn't budge. Wondering if it needs a starter rebuild or if there's a problem in the gearing.
Thanks for any replies,
Chris
