FI Light
My FI light came on today.... i noticed it blink on and off like twice while i was riding it... but it didnt stay on.. then i figured i'd shut the bike off and start it again to see what would happen, and now it is on all the time.. i did the self diag. check.. by grounding the wire under the seat... and it blinks 6 times really slow, then 3 times fast... what the hell does that mean??? when i found the codes.. these were what they said... i dont see how that could match up with these...
11 - Main throttle sensor malfunction
12 - Inlet air pressure sensor malfunction
13 - Inlet air temperature sensor malfunction
14 - Water temperature sensor malfunction
15 - Atmospheric pressure sensor malfunction
21 - Crankshaft sensor malfunction
23 - Camshaft position sensor malfunction
24 - Speed sensor malfunction
25 - Speed sensor malfunction
31 - Vehicle-down sensor, malfunction
32 - Subthrottle sensor malfunction
51 - Stick (Ignition) coil #1 malfunction
52 - Stick (Ignition) coil #2 malfunction
53 - Stick (Ignition) coil #3 malfunction
54 - Stick (Ignition) coil #4 malfunction
62 - Subthrottle valve actuator malfunction
help????!!!
