Originally Posted by SLIDER
are you asking if an 03-04 zx6rr frame is the same as an 03-04 636 frame? or do you want to know if the 03-04 the same as the 05-06 frame?
I will clairify my question: can I build up an 2004 636 (zx6r) using a 2003 zx6rr frame?
The only differences I can see between the two frames without measuring anything:
The RR has an adjustable swingarm pivot - the 636 does not.
The RR has a steering dampener provision welded on frame.
This article states the two chassis are the same:
http://www.sportrider.com/bikes/146_...6rr/index.html
