BikeBanditCheapCycleParts.comATV.comRacer Parts WholesaleSuperbikeToyStore.comMotorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Old 07-10-2008, 08:11 AM   #1 (permalink)
I Ride: 1994 ZX-11
Flushing the coolant system
After draining the coolant and seeing what appeared to be a large amount of dirt built up in the reservoir tank (14 years of being in the Arizona desert I presume), I need to flush the system. Any suggestions on doing this? Should / can I just use water straight from a hose. Or can I use a flush solution (does any car coolant flush system work?) Any help would be great…..thanks
ArizonaZX11 is offline   Reply With Quote
Old 07-10-2008, 11:22 AM   #2 (permalink)
dirty13south's Avatar
I Ride: 2005 ZX10R
Any radiatior flush should work... I usally use prostone. Then I'l flush real good with a water hose...
Old 07-10-2008, 07:50 PM   #3 (permalink)
I Ride: 2006 Kawasaki ZX6R (636)
and make sure you use distilled water if you dont buy pre-mixed coolant... tap water has shit in it that over time will start to clog the coolant passages in the radiator, and also could promote corrosion in the coolant system..
Darkcloud3420 is offline   Reply With Quote
