Need some help/ suggestions. I have a 2000 9R and just this season it's beginning to stall when coming off of revs. It's doing it as the clutch is pulled in at lights, stop signs, etc... Thoughts?
Check the air fillter and I'd check the hoses to the ram air under the front fairing. Take off the Y valve and clean it out it is a small air filter that gets gunked up and lightly blow though the hose that goes under the tank from the front fairing.
You do not have to tank the tank off.. But if you do you might as well check your emission hoses and clean out the vacuum switch valve
