D2MotoBikeBanditJazzMotorsports.comATV.com5150 ConceptsMotorcycle.comMotorcycleToyStore
Old 07-08-2008, 07:12 AM   #1 (permalink)
I Ride: ZX6R F2 M Reg
ZX6R F2 frame split without being dropped HELP!!! :(
Hiya
anyone else had this?
frame split across the ali box section under my tank on left side, its almost gone right through now. Looks like it came up from the weld seam.
Any suggestions to get it fixed or does anyone know of an F2 Frame going cheap in the UK so I can avoid scrapping it?
I wouldn't be so gutted if I dropped it but the bike has never hit tarmac.
If someone just has an F2 with a blown engine they want to shift that would be good also, i spent loads getting the engine sweet then it does this :@
Rich
ZX6R F2
RichyBoy is offline   Reply With Quote
Old 07-08-2008, 07:49 AM   #2 (permalink)
dirty13south's Avatar
I Ride: 1998 ZX9R
If you take the motor out you can get the frame welded almost good as new. Some muffler shop will do it for you for pretty chep. Well at lesat chepper then a new frame
Old 07-08-2008, 08:20 AM   #3 (permalink)
I thought that but most places i've asked said because its in a place on view you have to take everything off the frame, weld it finish it then repaint or powder coat and then have it retested before it will be allowed back on the road .Last quote was more than the bike is worth and most guys wouldnt touch it :(
Rich
ZX6R F2
Old 07-08-2008, 09:48 AM   #4 (permalink)
I Ride: 1998 ZX9R
Only time it has to be inspected is if it has a salvage title. you don't need to take everything off the frame just everything around where it needs to be welded. (Motor & wireing harrness)
Old 07-08-2008, 11:20 AM   #5 (permalink)
SLIDER's Avatar
I Ride: 2007 ZX6R
not worth the time or money to have it welded, coated, and checked. check ebay for a new one...
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets
PowerBronze DB windscreen
Hyper Co rear spring
Shogun frame sliders
SLIDER is online now   Reply With Quote
Old 07-08-2008, 09:19 PM   #6 (permalink)
I Ride: 1998 ZX9R
You can spend $500-$1000 on a new frame or $300 to have it welded and powder coated up to you...
Old 07-08-2008, 09:32 PM   #7 (permalink)
CUCULANDRA's Avatar
I Ride: 2007 ZX10R SE
I Would Say Fix It.. Less Money Plus When Buying A Used One, Your Buying Someone Elses Headakes
CUCULANDRA is offline   Reply With Quote
Old 07-09-2008, 01:41 AM   #8 (permalink)
big problem, everyone i have contacted has said everything off the frame and quoted loads of money to do it :(
Rich
ZX6R F2
