MotorcycleToyStoreD2MotoJazzMotorsports.com5150 ConceptsMotorcycle.comATV.comBikeBandit
5150 Concepts
Old 06-29-2008, 03:28 PM   #1 (permalink)
clutch slipping?
well I just started riding my 95 zx9r, and when I shift it from neutral down to first, its like it jumps, its not smooth at all. could this be slipping clutch? the guy who sold it to me said he thinks it was low on clutch fluid? also the front tire is balled to no end, you cant even see threads at all, could this make the front end sorta jump? thanks, neil
newbie09 is offline   Reply With Quote
Old 06-30-2008, 03:29 PM   #2 (permalink)
you need to bleed the clutch line. get a new tire.
ninja11zx is offline   Reply With Quote
Old 06-30-2008, 06:01 PM   #3 (permalink)
ok, bleed the clutch line. one more question. the bike sat for 2+ years so I was gonna run some seafoam to clean out the carbs. well before I knew it the whole can had been poured and mixed with only 2 gal. of gas. (16 oz.of seafoam). could this make it hard to start, beings how it is more seafoam than directed? im sure yall are tired of these questions, but im trying to get this bike straight. thanx
Old 07-01-2008, 11:45 PM   #4 (permalink)
dirty13south's Avatar
I Ride: 1998 ZX9R
As for the sea foam I'd add some more gas to it. It can make it hard to start and it shouldn't really hurt anything but I'd still add a few more gal. just to be safe. As for the hopping It's NOT from the clutch. ALL KAWASAKI's come stock with a slipper clutch. It's made to slip when down shifting at high RPM's so tire doesn't slide out from under you. If you let the clutch out a little slower that will keep it from hopeing on you.
