My ZX6R Missed mainly at around 6 thousand rpm. if you increse revs slowly it is smooth but if you open the throuttle write up it misses for about 4 thousand - 6 thousand rpm. i have taken off the carbs and cleaned them out allow everything looked fine with no majour dirt in them at all it has improved silghtley but still a problem at 6 thousand revs any ideas ???? ive now had it on dyno and theny think it may be ignition / electrical problem any further ideas will be grateful
Chris
Reason: more info
