JazzMotorsports.comSuperbikeToyStore.comMotorcycleToyStore5150 ConceptsATV.comMotorcycle.comBikeBanditD2Moto
Old 06-20-2008, 09:21 PM   #1 (permalink)
Question Clutch plates changed but still having problems
Ok, so I have a 90 ZX10. The clutch was slipping really bad so I replaced the plates. Now that after the bike warms up, is starts slipping again. High revs with no gain. Please can someone tell me what else may be causing this? I hear that maybe air in my line can do it. Also I have no free play in my clutch lever. I bled my lines and I think I got all the air out, but maybe not. Can this be my problem or where else should I start looking? Thanks guys.
un4givon is offline   Reply With Quote
Old 06-27-2008, 03:38 PM   #2 (permalink)
dirty13south's Avatar
I Ride: 1998 ZX9R
did you change the steel plats or just the fiber? A bike that old the steel plates are problaby getting worn out. Also the type of oil you use can cause it.
Old 06-27-2008, 04:02 PM   #3 (permalink)
Shifty1's Avatar
I Ride: 2005 ZX6R
Or your clutch may not be adjusted properly. Make sure it is adjusted properly at the case before you adjust it at the lever.
Shifty1 is online now   Reply With Quote
Old 06-29-2008, 08:53 PM   #4 (permalink)
I Ride: Kawasaki ZX11
did you change the steel plates or just the fiber?
Agreed. If the steel plates are worn or warped, the clutch can still slip.
Air in the clutch line is not likely to be a factor.
awelch is offline   Reply With Quote
