JazzMotorsports.comAdvanstarMotorcycleShows5150 ConceptsBikeBanditMotorcycleToyStoreATV.comSuperbikeToyStore.comMotorcycle.com
5150 Concepts
Old 06-12-2008, 05:30 PM   #1 (permalink)
richardsantink's Avatar
I Ride: '92 ZX-11 (C3)
Free play on rear sprocket? ('92 zx-11)
Just wondering if this is normal.. I've got a '92 ZX-11 with 28K on it. All stock. When I put the bike on the center-stand and apply the rear brakes, I can move the rear sprocket a little bit (forward and back, maybe 1/16th to 1/8th of an inch if I were to mark it).
In other words, when I accelerate from a stop, the chain advances that much before the wheel actually turns...
Should I be concerned?
thanks,
Rich
Richard Santink
Mississippi Mills, ON
'92 ZX-11 (C3) - all stock
richardsantink is offline   Reply With Quote
Old 06-17-2008, 01:26 PM   #2 (permalink)
Kawi_T's Avatar
I Ride: 2001 ZX12R
Inside the wheel is a rubber cush-drive (thats what I've always called it, basically a rubber cushion). Its probably worn out and needs replacing. As I understand it, the rubber cushions the trans from shock induced by on/off throttle response. Basically when the bike starts chugging for whatever reason, the cushion protects the trans. My brother has a bike with a sprocket mounted solid to the rear rim. When riding it, it is important to remember this and not let the bike chug (meaning try to ride smooth). My point is that this is an important piece. You should inspect it, probably replace it. Thats my 2 cents on the matter.
Tom
Quote from a Kaw mechanic (my dad)
"Great idea, buy your kid a ninja for his last birthday."
Kawi_T is offline   Reply With Quote
Old 06-17-2008, 02:12 PM   #3 (permalink)
I Ride: ZX11C 1993 , K1200LT 2004
My two cents is your right , check your rubber cushion . Dan
LIDMAN ZX11C
danielfjones is online now   Reply With Quote
Old 06-17-2008, 03:30 PM   #4 (permalink)
Yes, the cushion drive is prone to be short lived on a ZX11C.
Claude is offline   Reply With Quote
Old 06-25-2008, 11:17 AM   #5 (permalink)
Thanks everyone; you were right. Had it replaced.
RAS
Richard Santink
