2000 zx6r no power
OK I just joined, so forgive me if this is a repeat question. I have a 2000 ZX6R with 32K miles on it. I have owned it since new, and always performed routine maintenance. My problem is the bike has no power. It just happened all of a sudden. It's like it's starving for fuel at all rpm's. Things I have done within the last 2 weeks: adjust valves, clean air filter, clean carbs, sync carbs, replace fuel filter, check fuel pump, checked all coil sticks, check IC ignitor, check pickup coil, replace spark plugs, new gas in tank. I verified that each cylinder is getting spark.
I checked the compression before the valve adjustment, but not after. I did not check the throttle position sensor, because I don't have the test plug. I can just splice into the wires if I need to. The fuel pump runs, but I did not check it with a fuel pressure guage. My brother has the same bike so I swapped fuel pumps, but it ran the same. The bike uses no oil, and doesn't smoke at all. It ran like a dream before this. I'm an aircraft mechanic, so i'm no dummy. I just can't figure this one out. Any help is greatly appreciated.
