5150 ConceptsMotorcycle.comAdvanstarMotorcycleShowsSuperbikeToyStore.comJazzMotorsports.comMotorcycleToyStoreBikeBanditATV.com
BikeBandit
Old 05-17-2008, 09:58 AM   #1 (permalink)
NINJARDR91750's Avatar
I Ride: 1993 ZX750
Valve Adjustment And Carb Rebuild! Now A Bog Around 3-4 Rpms.
Like the title says i have a bog between 3 and 4 rpms. didn't have the bog before i had the valves adjusted and the carbs rebuilt. i think its probably a sync or vaccum problem but wanted some other imput. any other ideas for me?????
NINJARDR91750 is offline   Reply With Quote
Old 05-18-2008, 09:07 AM   #2 (permalink)
Kawi_T's Avatar
I Ride: 2001 ZX12R
Also sounds like a vacuum problem to me. Like the carb boots are loose and its sucking air. I've done that before and it makes the bike bog bad. I would check all the boots and air lines, etc. When the bike is running you can spray a little carb cleaner at the area you think may be leaking. If it is leaking, it will suck up the carb cleaner and cause the motor to rev. thats an easy/quick way to find vacuum leaks.
Quote from a Kaw mechanic (my dad)
"Great idea, buy your kid a ninja for his last birthday."
Kawi_T is offline   Reply With Quote
Old 05-19-2008, 03:08 PM   #3 (permalink)
I Ride: 1993 ZX750
THANKS FOR THE IDEA! i am in the middle of tear down then i will give it a try!!!!!
