Racer Parts WholesaleMotorcycleToyStoreATV.comJazzMotorsports.comSpringfield ArmorySportbikeTrackGearAdvanstarMotorcycleShows
Springfield Armory
Old 05-11-2008, 12:23 PM   #1 (permalink)
I Ride: 2005 ZX6R
FI light is on after my yoshi rs5 HELP!!!
hello im new to the forum and this is my first kawi i had a 2002 gsxr and i love it so i got this 05 ninja and i like it itws really nice. i installed a yoshimura rs-5 slip on exhaust on it and now my FI light is on can anyone help me to get rid of the light my bike stalls when i try to rev it when its cold help please!!!!!!
quierototolive is offline   Reply With Quote
Old 05-11-2008, 12:46 PM   #2 (permalink)
I Ride: 1992 zx 1100 with undercut trans, full muzzy exhaust,and all the other things to go fast
i will bet any money its because of an o2 sensor problem...u may have to take it to the dealer and have them run a program to re-map the bike for your pipe
mr.zx11 is offline   Reply With Quote
Old 05-11-2008, 01:24 PM   #3 (permalink)
I Ride: 2005 ZX6R
o2 sensor?? can it be the sensor that brings the rs-5 is there a correct way to installed??? i think if it was an o2 sensor the i would have a hard time reving it even tho the bike is hot or no???
Old 05-11-2008, 01:24 PM   #4 (permalink)
I Ride: 2005 ZX6R
is the re mapping an expensive fix?? o and thank you by the way!!!
Old 05-11-2008, 10:18 PM   #5 (permalink)
the o2 sensor monnitors the air to fuel mixtue in the bike through teh exhaust gasses comming out...so if it was maped for a more constritive exhaust or if there was a catiletic convertor that was taken out to install the pipe..the senser could be reading wrong and running a leaner or richer mixture of air/fuel then needed....with a FI bike most of the time the bike has to be re-maped to correct the diffrence...with a carb. bike it has to be re jetted. ......now as for cost if you wanted to spend a little more money you could get a powercommander and a FI controler for your bike..make alot of power, have a ton more settings and the touch of a button, and have the freedom to re map your bike anyway you choose with download able maps from the web site they provide. i would take it to the dealer first and let them run teh check light and see what code it throws..if it throws an o2 then you know it needs to eb re maped most likly but if it throws somthing elce you can go from there.....let us know what happeds hope i was help
live life, ride a kawi.
Old 06-09-2008, 06:38 AM   #6 (permalink)
Hi
What about code 83? I have the same problem with FI warning light after big stone hit my bottom exhaust (between wheels) I check all sticks and exhaust.Looks okay,but i cant fix this FI warning light.Its something serious?
makumba is offline   Reply With Quote
Old 06-15-2008, 01:42 AM   #7 (permalink)
HybridNinja's Avatar
Originally Posted by mr.zx11 View Post
with a FI bike most of the time the bike has to be re-maped to correct the diffrence...with a carb. bike it has to be re jetted....
i ran in to this when i put on my first exhaust. if you put it on your self there should have been a wire that ran to a butterfly valve in your stock exhaust. it looks more like a cable that attached to a cam or something... you should hear it when you put the key in to the start position. its that thing turning under your seat. well there should have been a metal piece that came along with their exhaust. you must instal that "L" or "J" shaped aluminum piece where that thing is spining and that stops the FI light.
thats the easiest way i can explain it..
HybridNinja is offline   Reply With Quote
Old 06-15-2008, 09:06 AM   #8 (permalink)
If you have the power commander USB and you bring it to a qualified guy that has a dyno it will cost a lot... i know from experience but if you load the generic map from the site (assuming again you have the Power Commander USB III) its relatively cheap... [not really recommended, because every engine is different. but it gets it in the ball park...]
'05 Ninja ZX6-R
Looks
Sato Sliders
Woodworks stator
& ign cover
Carbon Fiber inlay
Puig smoke W/S
Single seat cowl
Power
K&N Air filter
Power Commander III USB
2 bro Carbon slip sucked....
Acrapovic Full Ti EVO system
Vortex Front and rear CAT5 sprocket
RK chain
Controls
CRG folding clutch leaver
CRG folding brake leaver For Bembo 19x18
Vortex rear sets
Stopping power
Brembo 19x18 brake master cylinder
EBC HH front rear pads
Michelin 2CT
She's spoiled
Old 06-24-2008, 02:48 AM   #9 (permalink)
Thanks.I just found the problem.When I hit the ground,I broke sensor on the left side exhaust,and computer not recognize the fuel.I replace it and now works fine ;)
Kawasaki Rules :)
