» Site Navigation |
» Motorcycle Forums
» Links |
02-29-2008, 10:37 PM
#1 (permalink)
Scott's Steering Damper
Anyone have a Scott's steering damper?
-what does it feel like to ride with?
-Do you think it has saved you from a speed wobble?
-any negative points (apart from the price)?
thanks for any feedback.
1989 ZXR 750H & 2001 ZX-7R
02-29-2008, 11:24 PM
#2 (permalink)
I Ride: 06 kawi 10r in too fast orange, 06 CBR 1000RR Repsol and drive a 4 banger all wheel drive turbo charged go cart lancer contraption aka EVO
most dampners will. I like the ohlins and gpr
Drive like im about to do 25 to life and ride like a cheetah on cocaine
2006 KAWI ZX 10 R- ARATA full system in titanium, PCIII, custom map, bmc race filter, puig db
03-01-2008, 12:05 AM
#3 (permalink)
I Ride: green 07 kawasaki zx10r
except the ohlins on the 06/07 10r, (kawasaki spec). not a great difference at all between the softest setting and the firmest. mine stays on the hardest setting all the time, until my warranty is up!
03-01-2008, 12:32 PM
#4 (permalink)
what does the warranty have to do with the setting? do you void it if you turn the damper softer?
Also, what does turning feel like with a damper? is it more difficult to turn?
How about on the twisties? what happens if you dont change the setting to softer?
thx
03-01-2008, 03:13 PM
#5 (permalink)
It has nothin to do with the warranty. U can chage it now if u want to
Turning with a dampner is wierd at first, it takes gettin used too.
For twisties it helps a little, the biggest mod u can do is change ure suspension settings
03-02-2008, 03:36 PM
#6 (permalink)
yeah whoops, all i meant was theres not that much of a difference between the softest and hardest settings.full stop. and i wouldnt be altering anything such as a heavier oil used or changing the kawa spec needle to an original ohlins spec until after my warranty is up so i dont void it. sorry for my incomplete and somewhat confusing reply.
03-02-2008, 05:18 PM
#7 (permalink)
no worries,
the stock ohlins is not the best. I want the gpr myself
03-03-2008, 03:40 AM
#8 (permalink)
i'll have to put my left nut up on ebay to be able to afford one!!! hope it sells! lol
03-03-2008, 04:01 AM
#9 (permalink)
I Ride: ZX10R SE
^^ your expecting alot from a little NUT!!!!
03-03-2008, 04:04 AM
#10 (permalink)
I Ride: ZX10R SE
thx
I would be a little worried if a dampner affects your twisties riding. try a little more lean and a little less on the bars , your not riding a HD
03-03-2008, 06:26 AM
#11 (permalink)
 damn im gonna have to watch what i say with you now, anyways, i know youre the highest bidder jester!!! i dont know what you'd do with it... probably have something to da with cutting it in half and using it with a juicer....your favourite. youre one sick puppy!
