5150 ConceptsSuperbikeToyStore.comRacer Parts WholesaleJazzMotorsports.comMotorcycleToyStoreSpringfield ArmoryCheapCycleParts.comAdvanstarMotorcycleShows
Old 02-25-2008, 04:10 PM   #1 (permalink)
bigbrew's Avatar
I Ride: 97 zx7
chain cleaning?
should you clean your chain??? what is the best way of doing so???
bigbrew is offline   Reply With Quote
Old 02-25-2008, 05:11 PM   #2 (permalink)
Forum Leaders
Swoosh's Avatar
I Ride: '06 ZX-10R - in fast green!
YES!! of course you should.
Opinions vary on what is the best way to clean your chain, and what will or will not hurt it.
I've heard everything from soup to nuts for cleaning chains. (okay maybe not nuts but you get the point).
I use MOTUL chain cleaner... IMO its the best, with the least amount of effort. Put your rear tire up on the stand, spray the chain while rotating the rear tire.... then once it's all coated in cleaner, hold a rag under the chain and rotate the tire again. You won't believe how grimy and gummy your chain gets.
Once that's done, find a really good chain wax, or lube (again, I use MOTUL) and apply to the chain while rotating the rear tire. Even with good wax or lube, you need to let it set up. Don't spray your chain and instantly go peeling out... most of what you put on will fly off and end up on the inside of the chain guard, the undertail, etc.
I had an ex-girlfriend that said something to me once and it stuck with me... seems appropriate in this situation as well... she said "You can never have too much lube". I thought she was talking about greasing the chain on your bike... now I'm not so sure.
Originally Posted by Moleverine View Post
Newbies on liter bikes are just nature's way of providing spare parts to the other liter bike riders. And spare organs for others.
Swoosh is offline   Reply With Quote
Old 02-25-2008, 07:53 PM   #3 (permalink)
NOX
Kerosene
NOX is offline   Reply With Quote
Old 02-25-2008, 08:12 PM   #4 (permalink)
VOZ
Moderator
VOZ's Avatar
I Ride: WADDED 2002 ZX-12R
I use WD-40 to clean chain and chain wax by Maxim.
I soak chain with WD40 hold my grunge brush over and under the chain to romove all types of junk, then hit with a rag. Spray my chain wax and I'm good..
VOZ is offline   Reply With Quote
Old 02-25-2008, 08:15 PM   #5 (permalink)
BlueBomber14's Avatar
they make a brush for chain cleaning if you think you really need to scrub it it has three sides in a U shape.
I tend to agree with Swoosh's good advice.
Kerosene???? don't know if I would go that way on an o-ring chain personally, but as said above "from nut's to bolt's". There are to many good cleaners as swoosh pointed out that I'm more comfortable with.
NICE VOZ i typed and then when I came back there is the brush I typed about...it's magic!!!!
Old 02-25-2008, 09:01 PM   #6 (permalink)
NOX
DID says use kerosene on the box......., last time I had a o ring chain couple years ago. I use a non o ring. EIther way, soak it in kerosene, let it drip dry, use good lube. I wont say what I lube mine with, but I clean mine about every 20 miles........lol
Old 02-25-2008, 09:14 PM   #7 (permalink)
Yeah I try to get her to lube mine every......woops..wrong forum...this is the motorcycle one isn't it???
Old 02-25-2008, 10:36 PM   #8 (permalink)
Forum Leaders
Swoosh's Avatar
You clean your chain every 20 miles?? I'm going to have to call you on that one!! If I cleaned my chain every 20 miles I would never get anywhere... and I'd have no friends to ride with because they would get tired of stopping.
An average day for us would entail riding 300+ miles easily. So, if by your standards... I would have to stop 15 times during the day to clean my chain. Come on.... tell us you're kidding?
I have heard several people use kerosene...it's supposed to clean really well, and won't dry out the o-rings like other products such as (I've heard) WD-40. I personally wouldn't use WD for chain cleaning as it is almost guaranteed to dry out the rings IMO. It says it right in the name WD = Water Displacement... hence removal of moisture. As I said, to each their own, and if it works for you... then do it.
still about the "I clean mine every 20 miles", and hoping he doesn't mean his chain... but rather his "chain".
Old 02-26-2008, 09:37 AM   #9 (permalink)
MKP
MKP's Avatar
I Ride: ZX6R
I've used wd-40 to clean chains for years without any adverse effects. It doesn't "dry out the o rings". In fact some chain manufacturers even recommend it for cleaning their chains.
MKP is offline   Reply With Quote
Old 02-26-2008, 12:04 PM   #10 (permalink)
VOZ
Moderator
VOZ's Avatar
I have ESPN
Old 02-26-2008, 03:20 PM   #11 (permalink)
slim1100's Avatar
From: Australia, Foster (Wilsons Promontory) the southern tip of OZ
I Ride: ZX9R & zx10
Nox is only doing drag strips ....... from what I gather anyway otherwise like you say^^
freelance motorcyclist
So, to reiterate.... if you believe that you're a poser... do all of us riders a favour and sell your bike off cheap, and join a scrabble team or something.
slim1100 is offline   Reply With Quote
Old 02-26-2008, 03:55 PM   #12 (permalink)
kc10maineiac's Avatar
I Ride: 2005 ZX10R
I have pretty much followed the service manual to a T for a types of servicing. The manual states that kerosene and diesel oil is recommended for cleaning chains and O-rings of the drive chain. Do not use gas or trychloroethylene as it will cause deterioration and swelling of the O-ring. Immediately blow the chain dry with compressed air after cleaning. If you dont have a special chain lube, a heavy oil such as SAE 90 is recommended over lighter as you dont want it coming off when centrifical force does its thing. Apply oil to both sides of the rollers so that oul will penetrate to the rollers and bushings. Apply the oil to the O-rings so that the O-rings will be coated with oil....wipe off any excess. Well there ya have it guys, a special lesson directly from the zx-10 service manual. Hope it helps
kc10maineiac is offline   Reply With Quote
Old 02-26-2008, 11:24 PM   #13 (permalink)
n8dagr8's Avatar
I Ride: 2007 Passion Red Ninja 650R
I wish more people would read service manuals...
May the Horse Be With You...
n8dagr8 is offline   Reply With Quote
Old 02-27-2008, 05:16 AM   #14 (permalink)
Jester's Avatar
I Ride: ZX10R SE
^^ kawasaki also suggests that the platinum plugs that they come out with need to be changed every 12000km's and we al know that they should last double that so I am not going out of my way to trust everything that Kawa says.
I use wd-40 and have done for year with all my O ringed chains. They rings are sealed in lube so the Wd wont affect that and IMO chain lube just attracts and holds dirt and therefore keep's it in between friction points (generally not reccomended but hey each to there own) and the WD40 stops this affect. I will admit though that if you use WD as lube then you should apply more often as it is not as long lasting as lube
Jester is offline   Reply With Quote
Old 03-02-2008, 05:19 PM   #15 (permalink)
Bluesteiner's Avatar
all i've heard is that wd-40 will dry out the chain, why would you use it anyways when kerosene cleans soooo much better and is recommended, also, it's cheaper!
Parting out 1997 ZX9R! compatible with 94-97 9R's!
http://www.zxforums.com/forums/zx-9r...s-94-97-a.html
Bluesteiner is offline   Reply With Quote
Old 03-03-2008, 01:47 PM   #16 (permalink)
MKP
MKP's Avatar
I Ride: ZX6R
For me...WD-40 is cheaper than kerosene because I always have a can of the stuff (I never have kerosene so I'd have to buy some).
It also cleans the chain just fine and doesn't stink as bad as kerosene.
As far as "drying out the o rings", well it's just not true. I've used it on all my bikes for many years (I've owned more than 35 bikes in 35 years of riding) and never had any problems with the o rings.
Old 03-03-2008, 03:38 PM   #17 (permalink)
ZuluNinja's Avatar
I Ride: '07 ZX-14, '86 Honda VFR 750 & '03 Nissan 350 Z
bit of advice - never EVER clean your chain with regular gasoline. My chain lasted a lil bit over 15,000 miles with regular cleaning, oiling and tightening but the first 2 or 3 times I used gas and it seems that over time it really messed it up, my chain was making popping noises at 8,000 miles.
Now I use diesel that I keep on a spray bottle, jack her up on the stand and thoroughly spray while rotating tire, put a rag on the floor as it will drip filthy and get a grunge brush, that thing is meant for that. Brush entire chain thoroughly after spraying, wipe with a rag then apply whatever chain lube you use, there's plenty of them out there.
ZuluNinja is offline   Reply With Quote
Old 03-11-2008, 10:16 AM   #18 (permalink)
I Ride: 03 ZX-9R
I use wd-40 and a grunge brush, then lube it with either motul or chain wax and I have never had any problems.
Ochoa039R is offline   Reply With Quote
