AdvanstarMotorcycleShows5150 ConceptsMotorcycleToyStoreSuperbikeToyStore.comSpringfield ArmoryJazzMotorsports.comRacer Parts WholesaleCheapCycleParts.com
JazzMotorsports.com
Old 12-31-2007, 01:38 PM   #1 (permalink)
rich8363's Avatar
I Ride: 2008 C14
Angry Electronics Acting Up ??????
I installed a "Priorty Plus" on my C14 today.
When I turn the key switch to the OFF position, the front and rear flashers flash,
tach and speedo swing all the way to the right, and I hear the fuel pump wind up.
It does this 4 times then stops. It is doing what it normally does when you put the
key in the ON position.
The "Priority Plus" is a device that makes the turn signals running lights
and makes the flash for 1.5 seconds when you apply the brakes.
To install this, you have to cut the HOT to the LEFT and RIGHT turn signal
and connect the device between them. You also have to ground the device
and attach its power cable to the BRAKE wire.
I when to the local Kawasaki dealer where I bought the "Priority Plus" and the
lead mechanic was baffled.
Any ideas ????? I don't want to mess up my electronics, especially my fuel
pump or relay.
rich8363 is offline   Reply With Quote
Old 01-01-2008, 03:25 AM   #2 (permalink)
touchwoodsden's Avatar
I Ride: GTR1400, Tiger, various 2 stroke MZs
pump or relay.
illegal in the UK and would rally annoy me if I was following you. If the bike didnt do what you describe b4 u fitted it, IMHO, bin it. Sorry.
TwD
"I love the smell of 2-stroke in the morning"
touchwoodsden is offline   Reply With Quote
Old 01-01-2008, 06:33 AM   #3 (permalink)
Moderator
I don't know for sure if the lights are on the CAN bus, if so you are outta luck with the P+.
Ol' Wrench Head of the Booze Junkies MC
Ozzy is offline   Reply With Quote
Old 01-01-2008, 06:59 AM   #4 (permalink)
JamminJere's Avatar
I Ride: 2008 Concours14 #5361
Sounds like bleed of power thru the Ki-pass system somehow. I think I would try to return the bike to normal and hope this issue goes away. I don't think those lights are in the CANBUS.
There really isn't much difference between "the masses" and "them asses"....
JamminJere is offline   Reply With Quote
Old 01-03-2008, 07:46 PM   #5 (permalink)
rich8363's Avatar
I Ride: 2008 C14
Spoke with Doug. Says the Priority Plus is not
compatible with the C14's electronics.
Thinks the system my be doing some kind of a
voltage check and may not be finding what it needs
due to the circuit in the Priority Plus.
Thanks for all you help.
