» Site Navigation |
» Motorcycle Forums
12-27-2007, 06:44 AM
#1 (permalink)
Horn Upgrade
Swapped my pants OEM horn for a Stebel Nautilus Compact horn and produced this simple guide.
Thanks to Touchwoodsden for doing the hard work and finding a suitable place to mount the horn.
This horn is an excellent unit at a great price. Whole upgrade took 1 hour start to finish and sounds awsome..
http://s223.photobucket.com/remix/pl...fs=1&os=1&ap=1
Chris
12-27-2007, 08:16 AM
#2 (permalink)
I Ride: A Camel
Great video. The location chosen is the same I picked out to mount mine (once I get around to creating a bracket).
Is it really necessary to trim the trumpet in order to get it to fit? Would a longer bracket permit mounting without cutting?
Btw, not all stebels have the mount point at the top of the compressor, some have it on the side (like mine). An L bracket is not needed then, just a straight piece with 2 holes drilled.
12-27-2007, 09:51 AM
#3 (permalink)
I Ride: 2008 Concours14 #5361
I've had mine on for a few weeks now.. it works great! I have mine almost in the same spot but I just used very heavy HVAC ties around the right side air intake hose. no clearance issue and its not going anywhere... all other wiring is virtually the same as described in that nice powerpoint presentation. my trumpet are pointing down, the wiring pointing towards the rear of the bike..
See you on the road,
Jerry
There really isn't much difference between "the masses" and "them asses"....
12-27-2007, 11:44 AM
#4 (permalink)
I Ride: GTR1400, 140 trick monkeybike, various 2 stroke MZs, CX500 engined Morgan replica
Mine fitted without trimming too. I didnt even remove the fairing! But I did take the tank off. I love the video, with some cops and robbers music it would be like watching an old silent movie with the writing in that font. I bet the video took longer to make than the job took! I bet even Fred Harmon is impressed! It is also possible to mount without the L shape bracket as the little lug on the cornm body will take a loose M8 std full nut.
Well done one and all.
TwD
"I love the smell of 2-stroke in the morning"
12-27-2007, 07:32 PM
#5 (permalink)
I Ride: C14
Isn't there an easy way to get the sound. Geez, you gotta be a mechanic to even understand what comes off and goes on much less the wiring. Yikes. You guys are the best but I woundn't dare try this at home.
Yours,
Al
12-28-2007, 03:45 AM
#6 (permalink)
Yours,
Al
If you can undo one screw (which I am sure you can) you can take anything apart. All u need 2 do is remember what goes where. Rebuiling a 12 cylinder engine fro example is just like rebuilding 12 single cylinder engines all the same and at the same time!
I meta guy once who bought my old Blackbird. He even put the bike in to get brake pads changed AND to have the chain adjusted! More money than sense IMHO. Howver if you read the Kwak manual, virtually everything is down asa dealer job! I am reluctant to use a dealer for anything. 1st service for example, how do you KNOW what oil they use? Mmmm....
TWD
12-28-2007, 04:35 AM
#7 (permalink)
I Ride: Concours 14, SV1000s
Thanks for the 'how to', I haven't had a chance to even look for a spot for my horn, busy season at work. Have a 4 day weekend coming and will mount mine this weekend!!!
Thanks again
12-28-2007, 04:51 AM
#8 (permalink)
I had to trim a bit off as I wanted to keep a straight bracket and an upright compressor unit, as specified in the destructions without the need to have any dogleg bends in it. I also didn't want the horn rubbing the RamAir intake or possibly vibrating against the RamAir intake jubilee clip. The top of the horn compressor needs to clear the underside of the inner cover which has some heat proofing foam on the underside. As this cover is quite flimsy it would be easy for the horn to deform it when the cover is refitted allowing water to run under, hence the need to trim the trumpet to allow the horn to sit slightly lower. It makes no difference to the sound at all.
The Stebel Nautilus has two methods of mounting. One a large 8mm bolt and nut for side mounting also a small 5mm hole in the top which I used for my mounting position. Having two positions certainly makes mounting options easier.
Chris
12-28-2007, 09:08 AM
#9 (permalink)
I Ride: ZX11C 1993 , K1200LT 2004
Great job on install and video . Dan
LIDMAN ZX11C
12-28-2007, 08:32 PM
#10 (permalink)
I Ride: 2008 1400GTR (so says the Euro badging) 2008 ST1300 Honda XR650L
Excellent job Hitman....I will get to mounting mine soon.
12-29-2007, 03:55 AM
#11 (permalink)
I Ride: GTR1400 abs, FJR1300 abs
Nice job Chris, you have set a new standard for fitting guides
I am up your way in a few weeks time for the Torquay show, PM me your mobi number and we can sort out a pint in Paington or a beer in Brixham..
Stu..
12-29-2007, 06:32 AM
#12 (permalink)
Your on Stu....PM sent
Chris
01-01-2008, 05:30 PM
#13 (permalink)
Got mine on today, piece of cake thanks to the video instruction, thanks
Can't wait to use it!!!!!
01-02-2008, 01:26 PM
#14 (permalink)
Stu..
i could do with a pint myself
08-18-2011, 11:09 AM
#15 (permalink)
Looking for the Video? can someone send me the link?
08-18-2011, 03:54 PM
#16 (permalink)
I Ride: 2007 Sixxer
Did you see how old this post is bruh?
Sir Bald Knee'd, Peg Scrapin', Extreme Leanin' Sixxer Slut of ZXF
Graveyard Shitter Assistant To The Junior Whore Leader Passes @ The Gap This Year: 14 1/2
2CT’s
BMC Filter
SuperLite Sprockets -1/+2
Yoshi Slip-On
Rear Seat Cowl
AMSOIL Oil & K&N Filter
Block Off Plates (Ksouc77)
ZX Bar Ends
ASV C5 Shorty Levers
Driven D-3 Grips
Speedo Healer
Servo Buddy (Ksouc77)
Lithium Ion Battery
Motovation Sliders
SS Fender Eliminator
08-20-2011, 01:38 PM
#17 (permalink)
I Ride: GTR 1400
A lot of work there !!! I fitted the exact same horn but in a different place. I removed the right hand side long black plastic panel - the long thin panel underneath the right handle bar. I mounted my horn in the ample space in there with no problems. The wires powering the orginal horn even reaches by pulling them back up through the cable ties, so no need to extend cables or anything. Full job from start to finish 20 minutes.
If I knew how to post pictures I show a picture with the horn in place.
Dont ride faster than what your Gaurdian Angel can fly
| Sponsored Links |
