Hi Kev,
I'm not in the UK, but my fork development has been happening over recent months, with temps ranging from 0 - 15 here at home to 35 deg in Qld post revalve. I also reckon our roads are generally worse than those in the UK, so I don't think my experiences will be too far off.
I have found a definite improvement with a simple change to Silkolene Pro RSF 2.5w as discussed here
http://gtr1000.yuku.com/topic/4280/t...ork-Setup.html and here
http://forum.concours.org/index.php?topic=59828.0
Easy and cheap enough to do, and IMHO a definite improvement.
Its since been revalved and back to 5w and I'm awaiting springs. I'm shortly off to Africa for the rest of the month, so it'll be a while before I finish them, but I reckon if you think the standard forks are a bit harsh, you'll like the Silkolene version.
You can change the oil without removing the springs if you want, as spring removal is difficult in these forks. Remove the forks, but loosen the fork caps whilst the bottom clamp is still tight, and the top clamp loose. With the inner tube collapsed you will find the nylon preload spacer has two holes in it. You can then feed a zip tie down to use as a dipstick and find out what the standard level is when assembled. Hopefully they are the same. Then invert the forks and drain them, pumping them a bit. I measured what came out and it was close enough to what is specced in the manual. Refill, and I added 10mm to enhance bottoming resistance a bit and refit.
If you don't like it, change back, but then you'll know.
The problem with this bandaid is that you need to screw the rebound in to compensate, and the oil flow is quite low as a result and not optimum, which is why a revalve is better again.
Try it,
Steve
