» Site Navigation |
» Motorcycle Forums
» Links |
06-28-2009, 09:20 AM
#1 (permalink)
I Ride: Concours 14, Ducati ST2, KLR 650
Front tire removal?
I see the rear tire is a nut with a cotter pin to remove, but what is up with the front tire? Is it actually a giant hex bolt? I understand you have to loosen the four clamp down bolts, but how do you get the axle out? It looks like a hex key is necessary. What size hex socket is that and where can I get one? Help!
06-28-2009, 10:17 AM
#2 (permalink)
I Ride: '08 ZX10r
try a 13/16 spark plug socket. See if the wrong end will fit the hex key opening.
06-28-2009, 10:28 AM
#3 (permalink)
Administrator
I Ride: 2005 ZX6R
 That's what I do.
-Poetry written in gasoline.
06-28-2009, 11:47 AM
#4 (permalink)
It does fit perfectly!
Now how do I turn the socket? What are you putting in the other end to give you leverage to lossen and then tighten the axle down? Oh and thank you for the guidance.
06-28-2009, 01:03 PM
#5 (permalink)
I Ride: Kawasaki GTR 1400 black
Long scredriver for example
06-28-2009, 03:02 PM
#6 (permalink)
Administrator
I Ride: 2005 ZX6R
Run a 3" extension through the socket if you can and put a wrench on it. Basically, get your ratchet with an extension on it...then put the socket on the extension backwards.
06-28-2009, 03:05 PM
#7 (permalink)
thanks for the tip guys! I am about to take mine off as well and thought I would play hell fiding somthing to fit that thing.
06-28-2009, 07:59 PM
#8 (permalink)
Socket trick worked like a charm, thank you!
06-29-2009, 04:04 PM
#9 (permalink)
I Ride: GL1800, Concours-14, Honda Reflex
It's 22 mm hex. and needs to be torqued to 93.7 ft. lbs.
06-30-2009, 01:35 PM
#10 (permalink)
I Ride: Concours 1400, BMC, Power Commander V programed by Fuel Moto, 3/4 flies out, Area P slip on, 1994 ZX9R, 2008 KTM XCW, 2001 VFR 800
Motion Pro sells a tool that fits
http://www.motionpro.com/motorcycle/partno/08-0397/
07-07-2009, 04:40 AM
#11 (permalink)
22mm Hex Bit Socket
