» Site Navigation |
» Motorcycle Forums
» Links |
09-06-2008, 02:44 PM
#1 (permalink)
I Ride: GTR1400 Black
Butterflies removed
Today I removed my secondary butterflies
I took some pictures if someone is interested.
The procedure is easy and everyone who is not an absolute beginner i mechanics or driving a motorcycle should do it.
According to bench tests this will increse hp from 134 to 151 on rear wheel.
http://bike.cosmobob.com/viewtopic.php?f=3&t=118
09-28-2008, 12:23 PM
#2 (permalink)
I Ride: Kawasaki Concours 14
Welcome to the Dark Side...
09-30-2008, 09:03 PM
#3 (permalink)
I Ride: Kawasaki Concours 14 (aka GTR 1400)
Affect on fuel efficiency?
Does removing the butterflies affect fuel efficiency? I currently get anywhere from 36 to 44 miles per U.S. gallon, depending on speed and how "sporting" I ride. Does anyone have some before and after figures for comparison?
10-01-2008, 07:20 PM
#4 (permalink)
I Ride: C14, Harley Road King
I've had my flies out now for just over a month and I'm actually seeing an increase in my mileage. I was averaging 36-38 before removal and now I'm averaging 39. Small increase but how often do you get an increase in fuel economy with a performance increase?
10-01-2008, 08:22 PM
#5 (permalink)
I Ride: 05 ZX-10
Can This Be Done To A 2005 Zx 10. May Be A Stupid Question Just Want To Make Sure.
PIII,
HYPER PRO DAMPER,
FULL TI FORCEW/ FULL WRAP
GALFER BRAKE LINES,
FENDER ELIM. KIT,
DOUBLE BUBBLE,
VORTEX REARSETS,
CRG LEVERS
PEARL WHITE PAINT,WHITE SNAKE SKIN SEATS
FRAME MOUNTED SLIDERS
FLUSH MOUNTED LED SIDE SIGNALS,
HOT BODIES MIRRORS W/ LED TURN SIGNAL
SPROCKET SPECIALIST FRONT,AND REAR W/ 530 PITCH CHAIN
FACTORY PRO VELOCITY STACKS
SWING ARM PLATE HOLDER
VESRAH RJL FRONT PADS/EBC REAR PAD
PILOT POWERS
10-01-2008, 09:18 PM
#6 (permalink)
and what about ZX10R 2008,can i do it too?
10-02-2008, 07:51 PM
#7 (permalink)
I don't think you guys have the secondary flies in your bikes but I'm not totally sure. I'm headed to Kawi tomorrow and I'll check it out for you.
11-12-2008, 01:57 PM
#8 (permalink)
yes the 08 zx10's have flies, ants, cockroache's, & centipeede's if you must know....
11-13-2008, 02:21 AM
#9 (permalink)
I Ride: '07 ZX14
Are you using the power commander when you remove the flies? I believe there is a lean condition around 3,000 rpm. That would be the reason someone might see an increase in mpg.
11-13-2008, 04:17 PM
#10 (permalink)
I Ride: KX26R zx12R zx14 1400GTR
Yes you need to run a power commander with correct map to get rid of the lean spot. OR fit a TRE and you don't have to remove the flies or fit power commander. The TRE fools the bike into thinking it's in top gear all the time and opens up everything in every gear.
Race Hard or Go Home
11-13-2008, 06:25 PM
#11 (permalink)
Tre
What is this(,TRE )I have read on here that you do not need the PC III. When removing the Flies, and adding a slip-on Exhaust, and aftermarket air filter.
Is this not correct.
Any info would be great.
I have an 08 concours 14, changing it's look's Powder Coated Wheels( Black W/ Red Flake)Painted the Body Parts mostly Red Some parts Black,Lowering Link,Handle Bar Risers,Rad Guard,Headlight Guards,Two Bros TI Slip-on,BMC Air Filter,and New Roadsmart 2"s Front & Rear
