Motorcycle.com5150 ConceptsSuperbikeToyStore.comSpringfield ArmoryJazzMotorsports.comCycleGear.comSportbikeTrackGearCheapCycleParts.com
CheapCycleParts.com
Old 05-26-2008, 02:57 AM   #1 (permalink)
Oil change - is it worth it
I now have 1500 miles on the GTR and before I go off on a tour I thought I would change the Diff oil as it seems a bit murky again. Easy done so might as well
I am also tempted to change the engine oil and filter. Advice from you guys please. Is it worth changing or should i wait till nearer 3000. If I change should I stick with mineral or go semi synthetic - what are the pros and cons ?
Kev
Big Kev is offline   Reply With Quote
Old 05-26-2008, 04:35 AM   #2 (permalink)
Hammerhead's Avatar
I Ride: '04 ZZR 1200
If the break-in oil was changed at 5 or 6 hundred miles, you have a couple thou to go before it's necessary again. If you still have factory oil in the sump, get that crap out of there ASAP. Full synthetic, such as Mobil 1 4T, Amsoil 10W-40 4T and others are expensive, but provide superior protection and can extend change intervals. I use the Mobil 1 and change every 5K, but you could probably go longer than that with no probs. Synthetics do not gas off and change character from heat like dino oils, so they last longer.
Hammerhead is online now   Reply With Quote
Old 05-27-2008, 02:45 AM   #3 (permalink)
I Ride: Honda CBX1000, Kawasaki ZZR400, Honda 1100XX Blackbird, ZX14 in Red, Zongshen 200cc Scrambler; GTR1400 with TwoBrosTi, PC, BMC filter, Flies out.
You cannot change the oil too many time. With the heat build-up in the engine, I change about every 2,000km. At 2,000km on the clock went to semi-synthetic (Castrol Activo) will go to full synthetic at 6,000km (Castrol 4T) You hear so may stories about the superior protection of synthetic oils which is not good for a new engine trying to bed in. Should use a lower grade mineral oil to ensure maximum alowable friction during the bed in phase. Contacted a friend at a major oil company, he advises that at 2,000km al the bedding in should have taken place and you can go synthetic.
Frans is offline   Reply With Quote
Old 05-27-2008, 02:56 AM   #4 (permalink)
I Ride: 1992 zx 1100 with undercut trans, full muzzy exhaust,and all the other things to go fast
ive been told to run mineral oil for about suck as any shitty oil just not synthetic for teh first 500 to let the motor break in..then switch over to mobil 1 so i agree with hammerhead mobil 1 is the best
live life, ride a kawi.
mr.zx11 is offline   Reply With Quote
Old 05-27-2008, 08:28 AM   #5 (permalink)
Site Sponsor
Amsoil Dealer Group's Avatar
When using Amsoil's premium motorcycle oil you can actually run twice the OEM's recommendation. This is the only motorcycle oil on the market that is designed and recommended for this longer interval between oil changes. This scares most people, but one would surely not have to worry about needing an oil change while on a trip even with using a shorter interval.
george
ADG
We offer special prices and all products are shipped from the closest AMSOIL warehouse. For more info go to www.ezlubes.com or click on one of the banners.
Motorcycle Oil test data links http://www.ezlubes.com/product_info/g2156.pdf http://www.ezlubes.com/product_info/g2457.pdf
Amsoil Dealer Group is offline   Reply With Quote
Old 06-04-2008, 02:58 AM   #6 (permalink)
I Ride: 2008 Kawasaki 1400GTR (concours14)
I had my break in svc done at about 550 miles
then had the oil and rear end fluid done again at about 1500 miles
the mechanic said the engine oil looked just fine.
but the rear end fluid was dark, and had shiny bits in it.
I will do it again between 2500 and 3K
then switch to amsoil around 5K
KrautBurner is offline   Reply With Quote
Old 06-04-2008, 06:32 AM   #7 (permalink)
Site Sponsor
Should just be break in material, but the next time you service it pay attention to the fluid and make sure you have a lot less of these shiny bits of material. Let us know if we can be of assistance in getting you some Amsoil.
george
ADG
