BikeBandit5150 ConceptsATV.comJazzMotorsports.comMotorcycleToyStoreMotorcycle.comSuperbikeToyStore.com
5150 Concepts
Old 04-08-2008, 05:12 PM   #1 (permalink)
Flying Kaw's Avatar
From: As far from the government as humanly possible.
I Ride: Many
Question Ignition timing
I've already pulled the flies...added a TBR can and PC3. Now I want to tweek the ignition timing.
There's two ways to do this AFAIK:
1- get a run of the mill TRE. But apparently they ALL disable your gear sensor in order to trick the ECU into thinking it's always in 6th...
Or
2- Muzzy makes a timing advance plate. It allows you to advance the timing across the board up to 4 degrees. The only thing I'm not sure of it what the total advance is. The manual indicates 10.6 degrees @ 1100 rpm. But does any know what the maximal timing advance is in top gear?
THOUGHTS?
You must have a very fast bike because your were hauling azz when I passed you on my Concours
A FEW OF MY BIKES
Flying Kaw is offline   Reply With Quote
Old 04-10-2008, 03:38 AM   #2 (permalink)
Would the ignition module from Dynojet be an option?
psy1261 is offline   Reply With Quote
Old 04-11-2008, 03:52 PM   #3 (permalink)
I Ride: '07 ZX-14
I was about to say, all the ZX-14 drag guys are using this.
I have to wonder tho...will this cause any problems with the variable valve-timing in the C14 engine?
suprPHREAK is offline   Reply With Quote
