» Site Navigation |
» Motorcycle Forums
» Links |
08-17-2008, 05:12 PM
#1 (permalink)
I Ride: 1988 ZX-10 Ninja
Engine vibes causing hands to go numb
Here's the deal .
I need some suggestions or else I'm going to have to sell the ZX10 and look at a cruiser type ( NOOOOO ! ).
I have a problem with my right hand going numb and on fire / pain after more than a 1/2 hour of riding . I replaced the grips with gel grips and installed Gen Mar handlebar risers to take some pressure off the wrists . I found it made a great difference when I'm out riding for 30-40 minutes but today I went for an hour ride and had to shake it out numerous times and was in agony for most of the trip back home . I'm able to take the left hand off the grip and relieve the tingling/numbness but the right hand is really bad ( NO FEELING AND ON FIRE ).
I'm thinking of going to a bicycle shop and getting some thick foam handlebar grips , cutting them in half and cementing them on the gel grips . I get a real good engine buzz from 100 km/hr. and up .
I love the power and handling but this problem will have me out of the sportbike class for sure .
Any suggestions ( other than surgery ! ) ?
08-17-2008, 05:41 PM
#2 (permalink)
I Ride: 2007 ZX6R,KX125
don't grip the handlebar so hard and pinch the tank with your knees so you can take some pressure off of your arms.
2007 ZX6R
Catalytic converter cut out
Emissions system removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Vortex clip-ons
Vortex rearsets reverse shift
PowerBronze DB windscreen
Hyper Co rear spring
Sato front axle sliders
08-17-2008, 05:49 PM
#3 (permalink)
I'm sure that I'm only gripping enough to keep the throttle rolled on and the pressure has somewhat been relieved by the handlebar risers .
There is a product from www.crampbuster.com that looks promising and it's not expensive to try .
Thanks for your suggestion and I'll definitely concentrate on not gripping too hard and trying the tank squeezing .
08-17-2008, 07:24 PM
#4 (permalink)
I Ride: 2005 ZX10R
That's what I was going to suggest. The one at the local shop is marketed as the "throttle rocker", but it's essentially the same thing. I've thought about it myself, I was constantly shifting my right fingers around and gripping in different places to keep it from cramping up and it still would, usually within fifteen minutes. I do think most of it's psychological though, as far as how relaxed you are on the bike. Strangely enough, ever since I layed mine down, I'm far more relaxed on it and I've noticed my right hand almost never cramps up anymore. I don't think I was ever really gripping it that hard, but apparently I was. Relax, arch you back and let your abs take some of the weight.
-Jess
ΜOΛΩΝ ΛΑΒΕ!!!
"And he said O LORD God of my master Abraham, I pray thee, send me good speed this day..."
-Genesis 24:12
08-17-2008, 09:14 PM
#5 (permalink)
Thanks for your suggestions . I'll try it the next ride and keep you guys and gals posted as to what is helping the situation .
08-20-2008, 12:23 PM
#6 (permalink)
I Ride: 2005 ZX10R
So I finally broke down and bought this today. It looks gay and cost twelve bucks, but OMG what a difference! I should have got it months ago. It's unbelievable how much less strain is on your hand just by not having to grip the throttle to maintain speed, it's awesome.
-Jess
ΜOΛΩΝ ΛΑΒΕ!!!
-Genesis 24:12
08-20-2008, 04:00 PM
#7 (permalink)
I Ride: ZX7R
I also have a throttle rocker strapped to my ZX7R and it definitely makes a noticeable difference.. worth the $13.00 bucks to try it out.
08-20-2008, 04:46 PM
#8 (permalink)
hey also check your balancer in your engine i have the same problem and am getting it fixed soon when the fourth and first piston are up the balancer should be faced down
ask someone about it
08-21-2008, 12:13 AM
#9 (permalink)
I Ride: 07 Ebony SE
Also, get weighted bar ends, it cut's down on the bar vibes significantly, also, do the cruise control throttle mod, that way you don't have to grip it so hard when holding on, allowing for more blood flow and less pressure.
Officer:*Knocks on window*
Me:*Rolls down window*Yes officer may I help you?
Officer:I've been waiting all day for you.
Me:Well I got here as fast as I could.
Officer:*Laughs IntenselyI'ma let you off with a warning. It better not happen again, good day.
Me: Good day to you officer.
08-22-2008, 06:29 PM
#10 (permalink)
When I bought the bike , it had weighted bar ends already installed ( I wonder why ?!!! ) . I purchased the wide and thin model of the crampbuster and should have them in a week . By your comments , it looks like this will be a relief on the throttle hand . I will NEVER lower myself to riding a cruiser and I'm hooked on litrebike acceleration ! In fact , although it accelerates very quickly , I'm becoming quite used to it and could see MORE acceleration in my future .
08-22-2008, 08:01 PM
#11 (permalink)
I Ride: 2005 ZX10R
The more I get used to my "Throttle Rocker" the more I love it. It took some finaggling to find the right angle, it was either too low to maintain speed or too high and popping wheelies every time I sneezed; but once I got it in the right spot it's been a breeze ever since. No more gripping at all, acceleration is all in the wrist and you can just let your right hand rest on the bar like the left one. Wish I'd gotten it weeks ago!
-Jess
ΜOΛΩΝ ΛΑΒΕ!!!
-Genesis 24:12
