» Site Navigation |
» Motorcycle Forums
» Links |
01-06-2009, 06:30 PM
#1 (permalink)
I Ride: 2007 ZX6R
'07 ZX-6R Problems....Please Help!
Hey everyone, I have an '07 ZX-6R. My problem is that the bottom bracket to mount the fan snapped off from apparent road wear (has 19,000 miles). The result caused the fan to bend into the radiator and put two gashes in it. Until recently, the gashes posed no problem. When I noticed the radiator leaking last week, I got the bracket welded (currently still together) and the two leaks welded (some kind of weld that looks like hard maple syrup). It seems that the two radiator welds have melted from the header heat. Now the radiator is leaking again! If anyone can please tell me if there is a better solution, i.e. a better weld for the radiator or stop leak (not sure if it's good for bikes), I would really appreciate it! Low budget, so I'm looking for a quick and cheap fix!
Thanks everyone!
01-06-2009, 06:36 PM
#2 (permalink)
I Ride: '04 ZZR 1200
JB Weld is unaffected by heat once cured. It's a two-part epoxy with metal crystals mixed in. The trick will be to get whatever crap that's on there now completely cleaned off and the surface of the rad where the leak is happening clean and dry so the JB will stick.
01-06-2009, 07:25 PM
#3 (permalink)
I Ride: ZZR600
 to JB weld
make sure to get the right application epoxy i believe there is a specific JB weld for aluminum
2007 Kawasaki ZZR600 Black
Fender Eliminator
Custom rear turn signals
01-06-2009, 07:49 PM
#4 (permalink)
I Ride: 2007 ZX6R
Thanks for all your help! I'll try it out
01-06-2009, 07:53 PM
#5 (permalink)
I Ride: 2007 ZX6R
i just looked up the J-B cold Weld and it says it will bond to many metals including aluminum. is the standard J-B cold weld good then or do they make a specific JB weld epoxy solely for aluminum?
01-06-2009, 08:18 PM
#6 (permalink)
I Ride: 2007 ZX6R
in addition (i forgot to add previously) i have some oil leaking out from a gasket onto the header. it is a very gradual leak but enough to make smoke when the bike gets hot. I think someone previously posted something about the '07 6rs having a leak like this. any more help is much appreciated!
01-07-2009, 06:31 AM
#7 (permalink)
I Ride: ZZR600
the normal JB weld will do, and i believe the oil leak you have may be from the valve cover gasket
Fender Eliminator
01-07-2009, 06:40 AM
#8 (permalink)
I Ride: 2007 zx6r
yes it was a silent recall. It should now be an issued recall. I just had my gasket fixed a few weeks ago. If not buy a new gasket and put it on.
Those who can, do. Those who can't, teach.
01-07-2009, 05:03 PM
#9 (permalink)
I Ride: 2007 ZX6R,KX125
there is a recall on the gasket. they have designed a kit to solve the problem. call your dealer and have them order it. the repair should be free of charge. I believe the survice number for the recall is MC016-8
Cat cut out
Emissions removal
PCIIIUSB custom map
Jumper Mod
BMC race filter
Kawasaki velocity stacks
Driven Sprockets -1 +2
Vortex clip-ons
Vortex rearsets GP shift
PowerBronze DB windscreen
Ohlins ZX10 steering stabilizer 45wt oil
Hyper Co rear spring
Sato front axle sliders
01-09-2009, 12:12 AM
#10 (permalink)
I Ride: 2006 636
HOLY GOD .. 2007 and 19000 miles !!!!!!!!!!!
OR did you mean 1900 ?
I feel ODD since mine is a 2006 with 3000 miles ..
2006 Ninja 636 ZX6-R
Jumper Mod
Power Commander III
Powdercoated calipers and other items
Dash lights changed to green
Puig windscreen
I do Vinyl Decals for bikes at 1/2 the price as ANYONE , let me know if you need anything .
Check the website www.bikevinyl.com
Got a question , Email me sales@bikevinyl.com
http://i40.tinypic.com/jkypuq.gif
01-09-2009, 05:00 AM
#11 (permalink)
I Ride: ZX6-R J2
a 'get you home' solution to a radiator leak involves putting an egg white in your coolant system.
Not recommended for long distance trips in the scorching heat, but it'll get you home (just in case you ever have this experience again).
As for JB weld - I can vouch for that. It works quickly, and really well too. Definately worth trying.
If you can't be a good example, be a horrible warning
01-09-2009, 02:17 PM
#12 (permalink)
I Ride: 2006 636
I would rather buy a new radiator then patch it !
Jumper Mod
Power Commander III
Puig windscreen
01-11-2009, 03:30 PM
#13 (permalink)
I think this belongs in Mech&Tech or in the 6-shooter forum.
